post the laptop serial number and read this - https://www.badcaps.net/forum/troubl...93#post1635393
					Help with HP 830 G5 bios
 Please, these are the files of the bios admin passwordComment
 hi, tryAttached FilesComment
 peste Right in the attached file there is a Serial Number, the compressed file also has a serial photoComment
 LBTT1121 read the rules, the serial number must be typed and posted, not posted as a picture or part of the file name https://www.badcaps.net/forum/troubl...before-posting
 HP 830 G5 BIOS PASSWORD.Please the file you send, the SNID -- 5CG9086858 there is no display and this SNID-- 5CG905425P too is still lock.
 File 1**ProdID -- 2FZ83AV
 SNID -- 5CG9086858
 file 2** ProdID-- 2FZ83AV
 SNID-- 5CG905425PComment
 5CG905425P too is still lock. post both fileComment
 [QUOTE=MR KUJO;n3540422]HP 830 G5 BIOS PASSWORD.Please the file you send, the SNID -- 5CG9086858 there is no display and this SNID-- 5CG905425P too is still lock.
 SNID -- 5CG9086858
 hi tryAttached FilesComment
 please is it the main or the EC.By the way the attach file I have send is the main not the ECComment
 [QUOTE=shiyab;n3540431][QUOTE=MR KUJO;n3540422]HP 830 G5 BIOS PASSWORD.Please the file you send, the SNID -- 5CG9086858 there is no display and this SNID-- 5CG905425P too is still lock.
 SNID -- 5CG9086858
 hi try [/
 is not working.Standby light blinks dimComment
 Good Day
 Anyone, someone please assist to clear this error
 HP Security Endpoint Controller ERROR
 HP 830 G5
 SN/ 5CG84265JB
 i have uploaded the 32MB file Attached FilesComment
 try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
 Every donation made will go towards server fees and maintenance costs.Comment
 Please help me with my HP830 G5 bios password. The main lock bios IC is 25Q256JV, and the EC bios IC is IS25LP128-QKLE.
 FILE 1 : ProdID -- 2FZ83AV SNID -- 5CG9086858
 FILE 2 : ProdID-- 2FZ83AV SNID-- 5CG905425PComment
 hi try flash ec fileAttached FilesComment
 Hello, pls still need help. HP 830 G5 bios password. Thank you.
 ,FILE 1 : ProdID -- 2FZ83AV SNID -- 5CG9086858
 FILE 2 : ProdID-- 2FZ83AV SNID-- 5CG905425PAttached FilesComment
 hi try flash ec 16 mbAttached FilesComment
 Ok, I will try. But I think the FILE 1: ProdID -- 2FZ83AV SNID -- 5CG9086858 the MAIN BIOS BIN too has a problem, I change
 the bios bin before and there was no display, I went back to the old bin file (FILE 1 MAIN BIOS) but there was still no display,
 Please, help me with the FILE 2 EC.Comment
			by AhariHi all,
 I...-
			by mkdjDear all,
 I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
							Channel: BIOS Requests ONLY!
			by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
 Suspected Cause:
 Troubleshooting Attempts:
			Hello engineers 😀,
 🔧 Device Info:
 - Model: HP 15-da2007ne
 - Product Number: 8XF55EA#ABV
 - Serial Number: CND0338P0D
 - CPU: Intel Celeron N4000
 💀 Problem:😅
 - Device shows “Administrator Password”...2 Photos-
			by CityminHi all,
 S/N : 5RNK9FFT70...-
- Loading...
