Help with HP 830 G5 bios
  • henrysyndicate
    • Jul 2019
    • 8
    • Belgium
    Hi, i'need a dump of the HP 830 G5 bios,MoBo 6050A2930901-MB-A01.
    Thanks in advance
  • henrysyndicate
    • Jul 2019
    • 8
    • Belgium
    Re: Help with HP 830 G5 bios
    the laptop starts no video,then the fan starts working at max...nothing happens.
    i'think that the dump i'made was incomplete,and i'reflashed it so i'lost the any hope of fixing it...searched in all possible places (paid,free) but i'couldn't find it
    • ride_bmx_mhell
      • May 2018
      • 12
      • Philippines
      i up for these thread i also need 32,768kb file for bios,,i have a dump but it has a bios password,,i need to clear password pls help
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        Post here lock bios
        • ride_bmx_mhell
          • May 2018
          • 12
          • Philippines
          Originally posted by imranromi
          Post here lock bios
          yes here it is pls unlock bios pass thank you.
          https://yadi.sk/d/_P0-MY-NEpVnXA
          • imranromi
            • Jan 2015
            • 1288
            • Pakistan
            If you want help free post here bios dump.
            • ride_bmx_mhell
              • May 2018
              • 12
              • Philippines
              link already attach of bios dump,
              i cant attach file here it says file too large
              • ride_bmx_mhell
                • May 2018
                • 12
                • Philippines
                *edit*
                i rar the dump and it is now uploaded..
                Last edited by SMDFlea; 03-30-2023, 04:54 AM. Reason: Attachments cleanup,server space low.
                • imranromi
                  • Jan 2015
                  • 1288
                  • Pakistan
                  *edit*
                  Try this and post results
                  • ride_bmx_mhell
                    • May 2018
                    • 12
                    • Philippines
                    thank you,will try this and report back :salute:
                    • henrysyndicate
                      • Jul 2019
                      • 8
                      • Belgium
                      Thanks for the file...i'tried it on my laptop,but sadly it didn't work..screen keeps black,capslock blinks 5 times,then the fan starts working at max speed..any idea know where did i'screwed up?
                      • imranromi
                        • Jan 2015
                        • 1288
                        • Pakistan
                        This bios is not work your laptop as i know you have old bios original? Post here
                        • henrysyndicate
                          • Jul 2019
                          • 8
                          • Belgium
                          i'think the backup i'made was an incomplete one,here it is anyway in case you could fix it
                          • ride_bmx_mhell
                            • May 2018
                            • 12
                            • Philippines
                            yes my dump will not work to your model because of different me,use uefitool dump yours and replace my dump with your backup me in your dump...
                            @imanromi: my best friend send the laptop in a technician once it get back i will test this bin file asap
                            my best friend told me that the technician didnt have a bin file available so i told his to sent it back to me to test..
                            • ride_bmx_mhell
                              • May 2018
                              • 12
                              • Philippines
                              by the way is your bios chip labeled w25q256jveq? wson pacakge :noidea:
                              • ride_bmx_mhell
                                • May 2018
                                • 12
                                • Philippines
                                file tested and working thank you very much
                                • eng.umair.a
                                  • Jun 2016
                                  • 79
                                  • Pakistan
                                  Thanks imran bios worked but i am facing late display issue tried Clearing ME but issue remains can you help me?
                                  • imranromi
                                    • Jan 2015
                                    • 1288
                                    • Pakistan
                                    Why you program bios is no display password both condition post here old bios i will fix..
                                    • eng.umair.a
                                      • Jun 2016
                                      • 79
                                      • Pakistan
                                      Here is the old BIOS it had password but when i extracted it, it got damaged and after removing password did not display
                                      • imranromi
                                        • Jan 2015
                                        • 1288
                                        • Pakistan
                                        Try this file..
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
