Asus X441UB rev 2.1 BIOS
  • servis jaya.comp
    • Oct 2014
    • 33
    • Indonesia
    Hi All....any one Have Asus X441UB rev 2.1 BIOS....?
    Please Share it...
    Thanks..
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus X441UB rev 2.1 BIOS
    Post your bios dump here.
    • servis jaya.comp
      • Oct 2014
      • 33
      • Indonesia
      Bios Dump X441UB rev 2.1
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Try. your bios dump merged with asus official update.
        • servis jaya.comp
          • Oct 2014
          • 33
          • Indonesia
          OK...Thanks Master..BIOS tested OK..Laptop was display normally..but HDD and ODD not detected... mybe have a problem on other component...i am cecking again..
          thanks Master..
          • hazby1
            • Sep 2017
            • indonesia
            can you clear me this bios, please?
            • peste
              • Dec 2016
              • 12882
              • ROMANIA
              post the original bios here
              • lapfix
                • Mar 2020
                • 2739
                • my workshop
                Try and give Feedback
                • setiyo
                  • Mar 2018
                  • 36
                  • Indonesia
                  ok thank
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • kodox
                    Asus ExpertBook B1400CB Bios Dump Needed
                    by kodox
                    need original bios dump, original bios has flashed by other technician before me.
                    attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                    unit info:
                    Model: Asus ExpertBook B1400CBA-0711A1235U
                    S/N: R6NXNZ006657238
                    CN: 7F6F
                    Mainboard Code: B1500CBA R2.1...
                    Yesterday, 12:20 PM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
