Asus X441UB rev 2.1 BIOS
  • servis jaya.comp
    • Oct 2014
    • 33
    • Indonesia
    Hi All....any one Have Asus X441UB rev 2.1 BIOS....?
    Please Share it...
    Thanks..
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus X441UB rev 2.1 BIOS
    Post your bios dump here.
    • servis jaya.comp
      • Oct 2014
      • 33
      • Indonesia
      Bios Dump X441UB rev 2.1
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Try. your bios dump merged with asus official update.
        • servis jaya.comp
          • Oct 2014
          • 33
          • Indonesia
          OK...Thanks Master..BIOS tested OK..Laptop was display normally..but HDD and ODD not detected... mybe have a problem on other component...i am cecking again..
          thanks Master..
          • hazby1
            • Sep 2017
            • indonesia
            can you clear me this bios, please?
            • peste
              • 13656
              • ROMANIA
              post the original bios here
              • lapfix
                • Mar 2020
                • 2765
                • my workshop
                Try and give Feedback
                • setiyo
                  • Mar 2018
                  • 36
                  • Indonesia
                  ok thank
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
                  • DynaxSC
                    by DynaxSC
                    06-14-2024, 03:49 PM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
