need bios on Asus Q552U
  • chicocomputerclinic
    • Aug 2012
    • 5
    Hi guys! I had a client bring this in stating "I did an update, it lost power during it and now it wont turn on" he wasn't sure if it was a bios update but I assume it is because I get no charge indicator or anything... power is measured to the board so it seems to be getting power. I pulled the bios chip and have a dump of the current state it is in. I compared it to one downloaded from Asus in a hex editor and from my understanding you are supposed to combine the two somehow but I am not 100% clear on how to do that.. I'd love for this to be a learning experience for the next time it pops up so any information is greatly appreciated.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: need bios on Asus Q552U
    Your bios is definitely bricked. try this bios(your bios merged with asus web update)
      • Aug 2012
      • 5
      I'll try this first thing tomorrow morning, thank you!
        • Aug 2012
        • 5
        That worked!! You are great, thank you.
        Can you point me in the right direction to learn how to combine them in the future? I am going to sit down this afternoon and compare the two just to try and see the difference.
        Thanks again!
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Its simple. Extract bios region from your non working dump with UEFI tool and save it as "OLD BIOS REGN". Now download asus update file and compare size of both the files-it has to be 100% same. IF same in size, you can replace bios region with asus update in uefi tool and save the new bios and flash.
          In your case, the file was not same size. You need to compare both the files in hex editor and chop off extra bytes from web update to make it same size. To make matters worse, your old bios region header is corrupt-so it will be difficult for you to understand the beginning of file(in asus update). A little bit of experience will help but atleast you can try to understand by comparing the two files.
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • davidebeatrici
            Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
            by davidebeatrici
            I had 3 people contact me in a week because Windows suddenly didn't boot:
            As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
            The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
            Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
            06-17-2025, 12:59 PM
          • jinki_dadou
            ASUS ExpertCenter D700MD need update bios
            by jinki_dadou
            helle
            in have asus desktop
            model : D700MD-5124000950
            CPU i5 12400
            I wanted to upgrade the processor i7 13700
            when I change the processor show black screen and fan spinning fast
            i ask asus technical support
            the answer : include microcode in the latest update bios
            he give me file 1 update bios
            2 microcode
            2 fils in tha attachments please help me
            ( sorry for my dab english )...
            05-18-2025, 02:20 AM
          • mikeybass
            by mikeybass
            04-23-2025, 04:30 PM
