Asus x542uq rev 2.0 bios
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi I need a bios for this motherboard , I cant make it power on it just pump 800 milliamp on the board
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus x542uq rev 2.0 bios
    post your dump here as asus provides only update file.
    • cacla
      • Apr 2015
      • 442
      There is 2 models here are 2 bios one is yours
      • sel3370
        • Aug 2017
        • 18
        • turkey
        Thank you test ok
        • ahmetermin
          • Mar 2015
          • 38
          • batman
          asus x542ur-GQ276
          MOTHERBOARD :Asus x542uq rev 2.0 bios plase
          • peste
            • Dec 2016
            • 12835
            • ROMANIA
            Try..
            • cengiz47
              • Feb 2020
              • türkiye
              thanks my friend
              • vougheart
                • Jul 2020
                • 65
                • philippines
                can anyone tested file for my no display same board?
                • peste
                  • Dec 2016
                  • 12835
                  • ROMANIA
                  post the original laptop bios
                  • jocig58297
                    • Jan 2021
                    • 7
                    • ds
                    Hi i've an ASUS X542UR laptop, i need a BIOS Firmware is the X542UR-AS.rar good? i dumped one, i think is good.
                    • jocig58297
                      • Jan 2021
                      • 7
                      • ds
                      Hi, do you have any suggestion for that laptop
                      How can i send the fw that i dumped?
                      • Mazorca
                        • Jan 2017
                        • 463
                        Compress the dump, usually it's a .bin file with Winrar or similar, then add as an attachment to your reply.
                        • jocig58297
                          • Jan 2021
                          • 7
                          • ds
                          I dumped this and verified 6 times, so i think it's a good image.
                          This dump works, but it ask an unknow password at bios startup and i cannot go into Windows.
                          I dind't read the allowed file type... i was using a 7z file...
                          • Mazorca
                            • Jan 2017
                            • 463
                            Your file decompresses to 8,193 KB, I don't know if that is a problem. I managed to get a cleaned ME Region. Try it and give feedback please.
                            • jocig58297
                              • Jan 2021
                              • 7
                              • ds
                              u're right, it's better i try to dump it again?
                              • jocig58297
                                • Jan 2021
                                • 7
                                • ds
                                flashed, but it's still asking for that password, and i cannot enter the BIOS or start Windows
                                • Mazorca
                                  • Jan 2017
                                  • 463
                                  What is the date that it gives you? Press ALT key + r key then look at date. Another way is to remove the CMOS battery and/or the main battery if it doesn't have one, in order to reset the BIOS date to the earliest one possible. Then look for that date/password in the internet for Asus.
                                  • jocig58297
                                    • Jan 2021
                                    • 7
                                    • ds
                                    new laptops not have data, alt+r trick not working and there's no CMOS battery.
                                    For this reason i'm looking for a new flash
                                      • 20952
                                      The password is: nuovapasswordpc
                                      • jocig58297
                                        • Jan 2021
                                        • 7
                                        • ds
                                        wow...u're right, man!! i'm crying!!! How??? Tell me, please!!!
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • lrouw84
                                          by lrouw84
                                          Hi there,
                                          01-28-2023, 01:31 PM
