Macbook A1398 2014 15" 820-3787-A CleanMe Bios Dump
  • daltonjr.
    • Jul 2016
    • 45
    • Austria
    have another two bioses to clean, then i am done for some time
    I dont know if its relevant, it is mid 2014 15" A1398, 2,5ghz, 16gb, double graphics.
    Thanks in advance!
    • 20952
    Re: Macbook A1398 2014 15" 820-3787-A CleanMe Bios Dump
    Try it yourself its quite easy. https://ghostlyhaks.com/blog/apple-e...lean-me-region
    • daltonjr.
      • Jul 2016
      • 45
      • Austria
      i tried following that tutorial.
      I find ME region on the link, i think it should be that Intel ME 9.0 1.5MB Firmware v9.0.31.1487.
      But when i open 820.3787-a.bin there is no CRED in the decoded text.
      I find the C02... serial number, but no Cred that is mentioned in the tutorial link.
      I attach the efi again, because last one was bad. I was reading it from the board, it was bad contact or sth.
      • daltonjr.
        • Jul 2016
        • 45
        • Austria
        Crap, it si KRID
        • daltonjr.
          • Jul 2016
          • 45
          • Austria
          I dont know what am i doing wrong here. I do it as it is shown on that link, Copy/paste that clean ME to the locked EFI in the correct place, but it is still locked.
          Can someone help me to unlock this two in last two atachemnts. I am in a hurry right now.
          Thank you
            • 20952
            Thank you
            You wanted the ME cleaning, what do you mean by locked EFI,do you mean you want a password removing as well .
            • daltonjr.
              • Jul 2016
              • 45
              • Austria
              Yes it is password locked. So... clean ME doesnt mean password removal
              • daltonjr.
                • Jul 2016
                • 45
                • Austria
                I was searching for a clean bios dump for this board, but cant find it (for free).
                  • 20952
                  Here try these. ME clean and pass removed. Do a PRAM reset and reinstall the OS .
                  • daltonjr.
                    • Jul 2016
                    • 45
                    • Austria
                    It works! Thank you very much. I will learn it till next time... Greetings!
                    • mokujin
                      • Mar 2014
                      • Ukrain
                      Thanks! If someone is not in the know, then the serial can be found explicitly or by searching by the "ssn" parameter, at about 00630500.
                      • alexinquest
                        • May 2012
                        • 21
                        I'm looking for the same dump but for the 2013 macbook pro 15".
                        820-3787-A
                        A1398
                        I7 2.6Ghz and 16gb ram, nVidia graphics
                        I can clean the ME region myself.
                        Wondering if this one would work as well, even though it appears to be for the 2014 version.
                        Much appreciate somebodies upload for the 2013 version. Thanks
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          L2013/M2014 boards are identical.
                          • Wilfried
                            • Sep 2019
                            • 81
                            • Cameroun
                            hello
                            please i have a macbook pro A1398 which boots but does not display
                            can someone fix me this bios file 🙏🏿?
                            • peste
                              • Dec 2016
                              • 12835
                              • ROMANIA
                              Originally posted by Wilfried
                              hello
                              try..
                              • gugbobgug
                                • May 2022
                                • 14
                                • Georgia
                                hello i want to clean ME region
                                can anyone help me ?
                                  • 20952
                                  post your backup and serial number
                                  • gugbobgug
                                    • May 2022
                                    • 14
                                    • Georgia
                                    file added
                                    please help me
                                    • gugbobgug
                                      • May 2022
                                      • 14
                                      • Georgia
                                      sn is C02KV00EFJ47
                                      • elbtonet
                                        • Nov 2019
                                        • 105
                                        • albania
                                        Hi friend
                                        need password removal for my dump
                                        A1398 EMC2881
                                        sn: C02PF1M5G3QP
                                        • bussincaps
                                          MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                                          by bussincaps
                                          Hello All,
                                          tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                                          Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                                          eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                                          Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                                          I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                                          08-03-2023, 12:57 PM
                                        • rigway
                                          Apple Macbook Pro Mid-2014 A1398 - Battery detection FAIL
                                          by rigway
                                          Hi Everyone!
                                          Will be forever grateful if someone can give insight/direction.
                                          Got machine with liquid damage - Apple MacBook Pro 15-Inch "Core i7" 2.5 Mid-2014 (DG). Wasn't powering on completely. After inspection got the idea that charging IC is blows and couple more places of corrosion (swapped few more components form doner board).
                                          I have a spare working logic board with irrelevant physical damage (just a donor board to me now) Apple MacBook Pro 15-Inch Mid-2014 (IG).
                                          Replaced U7100 (ISL 6259) from it - powers on OK now, though battery...
                                          02-13-2022, 10:22 PM
                                          Apple MacBook Pro 15'' A1398 051-00330 820-00138 Schematic & Board View
                                          Apple MacBook Pro 15'' A1398 X435 051-00330 820-00138 Schematic & Board View
                                          A1398 main board resistance measurements (user submitted no further details)...
                                          10-01-2024, 06:58 AM
                                        • pippo_one
                                          Macbook a1398 emc2910 820-00426A
                                          by pippo_one
                                          Hi everyone, I have a MacBook a1398 emc2910 with an 820-00426A motherboard.
                                          I have a short on the "PPBUS_G3H" line... I traced it to the "U7310" IC
                                          FDMF6808N"
                                          and indeed the IC is shorted between "Vin and VSWH."
                                          On the motherboard, Vin to ground = open and it's OK.
                                          VSWH to ground = about 5,50 / 7.50 Ohms.
                                          With this measured value, can I safely replace this IC or is the CPU compromised?
                                          Do you have any other suggestions?
                                          Thanks for any help you can give me.
                                          07-20-2025, 03:35 AM
                                        • fisha
                                          Apple macbook Pro Retina A1398 Battery not charging
                                          by fisha
                                          Hallo everyone, my A1398 do not charging the battery and the battery also do not bin recognized. I did all the reset work, SMC reset and all the other reset options but nothing helped. on the SMC at pin 2 (DCIN) there are 20,4V coming in. at pin 16 (BGATE) which goes to the Q7155 Gate there are only 11,43V. at the pin 1,2 and 3 on the Q7155 (Source) there are 12,23V. Cap C7126 is not shorted. As I understand, the gate voltege have to by higher then the source voltege for the gate to clous so the battery can be charging, am I right? can someone help me with this? I guess that manny models are working...
                                          07-20-2024, 08:39 AM
