Dell latitude 7490 bios
  • hope1914
    • Oct 2020
    • 14
    • nigeria
    #101
    Re: Dell latitude 7490 bios
    Please wise guys I need the admin password of dell latitude 7490 with system number B0DC8S2-E7A8. THANKS PLEASE IS URGENT. here is my bios dump
      • 22293
      Password removal by laptop brand
      https://www.badcaps.net/forum/showpo...42&postcount=4
      • hope1914
        • Oct 2020
        • 14
        • nigeria
        #103
        i have tried this above but i didnt work. pls help
          • 22293
          You tried a USB US Qwerty keyboard ?
          • christian.ricard
            • Jul 2017
            • 26
            • Brasil
            #105
            Good morning, I have this 7490 with a password in the Bios, could someone clean it please, I already tried https://bios-pw.org/ , but it didn't work. Thank you very much.
            TAG: FWYS9X2
            • hardware1
              • Sep 2021
              • 2949
              • N/A
              #106
              TAG: FWYS9X2
              Try again with Password Generator.
              Use an External US Keyboard (QWERTY), use SHIFT Key for Uppercase letters, Hold left CTRL Key then Press ENTER Key twice.
              all donations are welcome,
              • christian.ricard
                • Jul 2017
                • 26
                • Brasil
                #107
                Tks, work perfect.
                • aleksandre.sarkisyan
                  • Aug 2021
                  • 5
                  • Tbilisi
                  #108
                  Hello
                  Can has anyone for Dell 7490 clear BIOS dump? Mobo IS DAZ40 LA-F321P rev:2.0 (A01) I7-8650U SN:GBDJJR2
                  PLEASE WHEN POSTED BIOS DUMP ALSO TYPE WHAT BIOS DUMP YOU DUMPING AS LIKE BELOW:
                  MOBO VERSION YOU CAN SEE UNDER DIMM RAM (A) EXAMPLE MY IS: DAZ40 LA-F321P rev:2.0 (A01)
                  CPU ID: I5-8XXX OR I7-8XXX ( EXAMPLE MY IS I7-8650U )
                  WHY I ASK? BECAUSE FOR DELL LATITUDE 7490 HAS DIFFERENT BIOS WITH DIFFERENT MODELS CPU AND MOBO.
                  • hardware1
                    • Sep 2021
                    • 2949
                    • N/A
                    #109
                    Originally posted by aleksandre.sarkisyan
                    Hello
                    I didn't get your Problem! Do you want to remove your BIOS Password or you need someone to fix your BIOS file?
                    Also upload your BIOS Backup here.
                      • Aug 2021
                      • 5
                      • Tbilisi
                      #110
                      Yes i need remove ADMIN pass
                      Thank you
                        • Aug 2021
                        • 5
                        • Tbilisi
                        #111
                        Thank you
                        I upload clean BIOS for 7490 DAZ40 LA-F321P rev2.0 (A01)_I7-8650U_CPU-ID_806en
                        This BIOS help me and boot up successful
                        • bigbadbios
                          • May 2021
                          • 8
                          Need the password removed for this bios please.
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #113
                            Post #102
                            Originally posted by SMDFlea
                            Become a Badcaps supporter
                            Thanks to all supporters.​
                            • jonyhdtv
                              • Mar 2021
                              • 18
                              Dell latitude 7490 bios Computrace
                              i have Dell Latitude 7490 with computrace active
                              motherboard : DAZ40 LA-F321P Rev 1.0 (A00)
                              can anyone help me remove this?
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #115
                                Re: Dell latitude 7490 bios Computrace
                                Use the dump at post #111
                                Your Service Tag is FTCYNQ2, input the ST at first boot, disable Computrace, then save and restart. Alt+F to exit MPM at second boot.
                                • jonyhdtv
                                  • Mar 2021
                                  • 18
                                  Before I make a bios change (new bin), do I clear ME first?
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #117
                                    No use the file as is, it's already has clean ME firmware.
                                    • jonyhdtv
                                      • Mar 2021
                                      • 18
                                      I can't change the ST? After the first start I pressed F2
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #119
                                        I don't know what you did but first tell me about the Computrace, if it's disabled now I'll suggest you to leave it this way.
                                        • jonyhdtv
                                          • Mar 2021
                                          • 18
                                          I can set only Disabled. I can't set Permanently Disabled
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • Sathsul
                                            Dell Latitude 5431 issues with dumping bios
                                            by Sathsul
                                            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                            10-28-2025, 07:49 AM
                                            DELL Latitude 7490 Notebook 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude 7490 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7490 boardview and 7490 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7490...
                                            09-06-2024, 12:36 PM
                                            09-06-2024, 12:13 PM
