13092-1 bios plz
  • mahmoodjavan
    Banned
    • Mar 2018
    • 584
    • iran
    13092-1 bios plz
    Dell 20-3015
    bios dump plz
    • 22275
    Re: 13092-1 bios plz
    Post your bios backup,if you have it.
    • bmxlovah
      Dell Precision T7910 no bios, no post after applying SAS/RAID setup
      by bmxlovah
      My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...
      11-24-2022, 06:29 AM
    • mikeybass
      by mikeybass
      04-23-2025, 04:30 PM
    • capoplays
      Help with BIOS update on Dell G15 5515 after chip replacement
      by capoplays
      Hey everyone,
      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
      When I check the BIOS using the F12 menu Flash...
      10-24-2025, 06:53 AM
    • jhanra
      by jhanra
      11-02-2024, 04:19 AM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
