dell latitude e7470
  • duder
    • Oct 2013
    • 26
    • canada
    #61
    Re: dell latitude e7470
    Ok - Here is the bios removed from the board and it looks the same as the one I did on board. Not sure what I am doing wrong. I am using CH341 programmer and I tried with Asprogrammer as well as NeoProgrammer. I picked winbond 25q128fv, hit read and then save. Then zipped file.
    • hardware1
      • Sep 2021
      • 2930
      • N/A
      #62
      Both files are not Identical and they are not good.
      You said that you have tried another files, is that means you lost the original backup and there is another file on the chip?
      all donations are welcome,
      • duder
        • Oct 2013
        • 26
        • canada
        #63
        No, I never lost the originals and I put the original back on the chip after trying the others. Here are some other backups. Backup 1 and Backup2 were taken with clip and different software. I never modified the originals either.
        • hardware1
          • Sep 2021
          • 2930
          • N/A
          #64
          You didn't take the proper backup from the chip at the first time. However, I attached a BIOS for your device and you can try it.
          Use NeoProgrammer and remember to select verify the chip after flashing it.
          • duder
            • Oct 2013
            • 26
            • canada
            #65
            Wow! I am amazed. It restarted a few times and then I saw the display for the first time. Then I set it to UEFI and it booted windows and then restarted and updated firmware by itself. I was beginning to think that this wasn't a BIOS issue, except I had read other posts which had the same issue. What causes this to happen? My client said he used it one day without issue and the next day it would not power up. I guess my mistake was reading the BIOS while it was in circuit, even though I had the battery disconnected. The CMOS battery was still connected though. At the moment, it appears that everything is working perfectly. Thanks again for all your help.
            • hardware1
              • Sep 2021
              • 2930
              • N/A
              #66
              Wow! I am amazed. It restarted a few times and then I saw the display for the first time. Then I set it to UEFI and it booted windows and then restarted and updated firmware by itself. At the moment, it appears that everything is working perfectly. Thanks again for all your help.
              It's good to know, you're welcome.
              • atlantis2
                • Apr 2022
                • 24
                • Poland
                #67
                Hello, Please help with BIOS repair - notebook won't boot (no display - switch off after 3 sec)
                  • 20888
                  You must post the service tag
                  • atlantis2
                    • Apr 2022
                    • 24
                    • Poland
                    #69
                    Service TAG: B7KJJC2
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11735
                      #70
                      Latitude E7470
                      Service Tag: B7KJJC2
                      • badcapsdroid
                        • May 2021
                        • 6
                        • paris
                        #71
                        Hello, work perfectly on my computer, very big thanks to you.
                        • metlj
                          Mehdi
                          • Jan 2023
                          • 18
                          • america
                          #72
                          Try this one,give it a few minutes to statrt/restart. If it boots up ok then run the latest bios update from dell to update the bios and EC .If it doesn`t make any difference the problem isn`t with the bios.
                          thanks bro works 100% no delay
                          • knguyenfl
                            • Mar 2023
                            • 8
                            • usa
                            #73
                            Hi, I have Dell Latitude E7470 with computrace activated on bios, can someone please help me reset or disable computrace?
                            Thank you.
                            Service tag: D8MP2H2
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11735
                              #74
                              Thank you.
                              Latitude E7470
                              Service Tag: D8MP2H2
                              • knguyenfl
                                knguyenfl commented
                                Editing a comment
                                It worked, thank you so much HoaCa388
                            • florenz
                              • Apr 2018
                              • 43
                              • Cameroon
                              #75
                              Try This one .
                              Hello Badcaps, Hello Super moderator
                              please i need your help for a dell e7470, computrace is locked. the bios was also lock but i succefully unlock it but because of you cant work with the machine.
                              SERVICE TAG / HWKYMC2
                              • qayyum786
                                • Aug 2018
                                • 1933
                                • INDIA
                                #76
                                Replace bios region only or flash configured bios from above post 74
                                • florenz
                                  • Apr 2018
                                  • 43
                                  • Cameroon
                                  #77
                                  hI THX FOR THE REPLY ? I DONT KNOW HOW TO CHANGE BIOS REGION ( any tutorial for me ?)
                                  i can easily flash the bios , should i use my same service TAG?
                                • testinglaptops
                                  • Oct 2022
                                  • 76
                                  • United Arab Emirates
                                  #78
                                  Originally posted by Markus1741
                                  Re: Dell Latitude E7470, clean BIOS
                                  Try dudochnicht ....
                                  100% Worked for me. Thank You. Fast Display
                                  • dariusgc
                                    • May 2020
                                    • 35
                                    • Lithuania
                                    #79
                                    Can someone rebuild bios? I cleaned ME region, but unfortunately didn't helped.
                                    Service Tag: 34XRR72
                                    • volinakis
                                      • Jan 2021
                                      • 2733
                                      • N/A
                                      #80
                                      try
                                      • gizaha
                                        by gizaha
                                        02-13-2024, 07:18 AM
                                        DELL Latitude E7470 Notebook 7000 Specification for Upgrade or Repair
                                        This specification for the DELL Latitude E7470 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E7470 boardview and E7470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                        09-06-2024, 10:00 PM
