dell latitude e7470
  • kamel
    • May 2011
    • 129
    • TUNISIA
    • COMPUTER-ELECTRONIC-CHESS
    #41
    Re: Reflashing Dell E7470 AAZ60 LA-C461P Rev1.0(A00)
    Originally posted by Vesko356
    Here you are, your original dump with with 1.05.03 version bios update, same as in your corrupted dump, try it and come back with some feedback. If the problem persist, I'll clean the ME firmware additionally.
    Edit: Again, we've replied almost at the same time with Hardware1, I leave the dump I prepared, it is better to try it first, because it is with your factory ME firmware, and for me it is better to stay with it, but if as I said the problem persist, try the Hardware1's one - it has clean ME firmware.
    Thanks for your prompt help. Unfortunately, got no display though all voltages are ok. CPU voltages appear for seconds and then laptop is off.
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      • Gadget & motorcycle addicted
      #42
      You are out of luck, usually the bios region gets corrupted, with the ME firmware it happens much less often, it would be good to stay with the factory one, but what can we do. So we go to option two as a way out. Go ahead.
      Become a Badcaps supporter
      Thanks to all supporters.​
      • hardware1
        • Sep 2021
        • 2956
        • N/A
        #43
        Have you tried the file in Post #39 as well?
        all donations are welcome,
        • kamel
          • May 2011
          • 129
          • TUNISIA
          #44
          Here's your New BIOS, try it and let me know.
          Service Tag: HYJFKC2.
          First, thanks for your submission. Tried dump, but unfortunately no display.
          Is there any way to fix the attached working dump with no wifi detection ?
          • hardware1
            • Sep 2021
            • 2956
            • N/A
            #45
            Try this one and see, it has the same version as the working file with WIFI issue.
            • kamel
              • May 2011
              • 129
              • TUNISIA
              #46
              Unfortunately, this version gave no ram voltage, so no display.
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #47
                Try the dump I've posted for another member- it's unlocked, ME cleaned and confirmed working.
                https://www.badcaps.net/forum/showpo...6&postcount=65
                • kamel
                  • May 2011
                  • 129
                  • TUNISIA
                  #48
                  First thank you for your continuous help. Unfortunately got no display though all voltages including CPU voltages are ok for seconds then laptop shuts down.
                  • anna1203
                    • Mar 2019
                    • dasdasdasdas
                    #49
                    Re: dell latitude e7470
                    plss clear me
                    • Markus1741
                      • Sep 2020
                      • 999
                      • N/A
                      #50
                      Originally posted by anna1203
                      plss clear me
                      Try this file ...
                      Good luck ...
                      • anna1203
                        • Mar 2019
                        • dasdasdasdas
                        #51
                        tnx i try
                        Try this file ...
                        Good luck ...
                        no display,,,,but thanks sir
                        [Mod. Edit-Vesko356] Use if you want to add something instead of posting new reply!
                        • shvanahmad61
                          • Dec 2022
                          • 11
                          • sulaymanyah
                          #52
                          Dell E7470
                          Hello Guys
                          i have a dell E7470 has 2 issues not fan spining and not display
                          please can you Clean the bios or Re create the bios
                          Dell E7470
                          Service : JBC5TC2
                          • eric2022
                            Ericscott
                            • Jan 2022
                            • 51
                            • Uganda
                            #53
                            i have changed ram of all frequencies but i have failed to over come the error code of 2amber 3 white for dell e7470. Any one can help me
                            • mohammed mohan
                              • Nov 2017
                              • 210
                              • F12
                              #54
                              thanks
                              • dudochnicht
                                • Nov 2020
                                • 30
                                • GER
                                #55
                                Dell Latitude E7470, clean BIOS
                                Hi, i need a clean BIOS Dump. Thanks :-)
                                Model: Dell Latitude E7470
                                Board: AAZ60 LA-C461P Rev:1.0
                                • Markus1741
                                  • Sep 2020
                                  • 999
                                  • N/A
                                  #56
                                  Re: Dell Latitude E7470, clean BIOS
                                  Try dudochnicht ....
                                  • dudochnicht
                                    • Nov 2020
                                    • 30
                                    • GER
                                    #57
                                    Thanks, this works for me :-)
                                    • duder
                                      • Oct 2013
                                      • 41
                                      • canada
                                      #58
                                      Hello - I have Dell e7470 that turns on with no display and shuts off after 30 seconds. I have tried numerous bios in this thread with different results but no display. I wonder if some could take a look at this bios? Service tag is 2PPDVD2. Thanks in advance.
                                      • hardware1
                                        • Sep 2021
                                        • 2956
                                        • N/A
                                        #59
                                        Your backup is messy, and we can't repair it. I think you are using a clip to read the BIOS chip.
                                        • duder
                                          • Oct 2013
                                          • 41
                                          • canada
                                          #60
                                          Thank you for the quick response. I was using a clip with battery and power disconnected. I will try again after removing the chip.
                                          • TopPop
                                            Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                            by TopPop
                                            Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                            I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                            12-14-2025, 09:40 PM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • Boardview and Schematic Bot
                                            DELL Latitude E7470 Notebook 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Latitude E7470 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E7470 boardview and E7470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                            09-06-2024, 10:00 PM
