bios dell vostro 3559 la-d071p
  • poweron
    • May 2019
    • 371
    • italy
    Hi, I am looking for bios bin for Dell Vostro 3559 AAL15 LA-D071P Rev: 1.0 chip W25Q128BV, I tried several files but they don't work
    happy day
  • peste
    • 13100
    • ROMANIA
    Re: bios dell vostro 3559 la-d071p
    try..
    • poweron
      • May 2019
      • 371
      • italy
      thank you, I will update you on the result
      best regards
      • poweron
        • May 2019
        • 371
        • italy
        does not work, as soon as I connect the power supply, the poweron LED lights up, after 15 seconds the LED turns off and the fan starts to turn at maximum and remains so until power is disconnected.
        • peste
          • 13100
          • ROMANIA
          what defect it had at the beginning?
          • peste
            • 13100
            • ROMANIA
            Try this new one.
            • poweron
              • May 2019
              • 371
              • italy
              it went out by itself while it was working and it never turned on again, it just turned on and that's it
              thanks, now I try this new bios
              • poweron
                • May 2019
                • 371
                • italy
                unfortunately this also does not work, it turns on by itself with the LED on and fan on, I tried other bios but gave no signs of life, can it be a micro-ec problem?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  If you write a new bios on this mobo, it usually turns on automatically and fan does spins at max speed and it will restart a couple of times(i think 3 cycles) and then display comes. the screen has to be attached to boot. Did you waited that long??
                  • poweron
                    • May 2019
                    • 371
                    • italy
                    good morning, I waited 4 or 5 min but the fan always runs, I have not connected the display, now I will try again with the display connected and the ram and let me know if it works
                    thank you
                    • poweron
                      • May 2019
                      • 371
                      • italy
                      I left the notebook on with the fan at the most and after 2 hours it is still running, I think it's a little too long, the chip is recognized by the programmer so I think it's good, I tried a bios and with this the LED had no white light but amber however the fan did not start but only the led was on
                        • 21362
                        Post your original bios backup if you have it . What is your service tag number .
                        • poweron
                          • May 2019
                          • 371
                          • italy
                          hi SMDFlea, unfortunately I don't have the original file, when I extracted it I couldn't save it, the service tag is this: F0T8Q72
                          thank you
                          • imranromi
                            • Jan 2015
                            • 1288
                            • Pakistan
                            Maybe then not problem in bios.You check all coil have voltage?
                            Try this i checked many time all time work.If same then not a problem bios.
                            • poweron
                              • May 2019
                              • 371
                              • italy
                              some coils have no voltage, I try this bios and if it doesn't work I'll look for the problem on the board
                              thank you
                                • 21362
                                I`ll post my bios as it has the latest bios update and CLEAN ME firmware.
                                • poweron
                                  • May 2019
                                  • 371
                                  • italy
                                  from a quick check I found that the + VCC_CORE and the + VCC_GT are missing
                                  • poweron
                                    • May 2019
                                    • 371
                                    • italy
                                    Originally posted by SMDFlea
                                    I`ll post my bios as it has the latest bios update and ME firmware.
                                    thank you
                                    • poweron
                                      • May 2019
                                      • 371
                                      • italy
                                      with this last bios connecting the power supply, the power led lights up for 3 sec then turns off, but the fan remains still and if I press the power button nothing happens, like it did at the beginning when I opened it the first time with the original bios,so i think this may be the original bios
                                        • 21362
                                        The problem isn`t the bios.
                                          DELL Vostro 3559 Notebook 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Vostro 3559 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3559 boardview and 3559 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 3559 Notebook...
                                          09-06-2024, 06:11 AM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • 417731
                                          BIOS needed for Dell Vostro 3405
                                          by 417731
                                          Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                                          Model: Dell Vostro 3405
                                          Tag:F0B1YF3
                                          CPU:Ryzen 3500U
                                          Thanks in advance
                                          07-06-2025, 06:48 PM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • sammus540
                                          Dell Vostro 3420 BIOS Password Removal
                                          by sammus540
                                          I have a Vostro 3420 8H8K5R3​-8FC8 that freeze at any attempt to enter bios password or the recovery master password received from dell. I do not have a clean BIOS image to flash.
                                          And as luck would have it happened a couple of months ago right outside of the warranty period (Dec 2023) warranty expired in September. Any help or guidance is appreciated.
                                          03-28-2024, 06:33 PM
