Lenovo thinkpad E330 bios bin needed
  • eng.jaudat
    • Aug 2016
    • 63
    • Palestine
    Lpr-1 mb
    11284-2
    48.4uh01.021
    thank you
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: Lenovo thinkpad E330 bios bin needed
    try...
    • eng.jaudat
      • Aug 2016
      • 63
      • Palestine
      thank you my friend,
      i will try it and feed back after that.
      • eng.jaudat
        • Aug 2016
        • 63
        • Palestine
        its working, but the problem still present, i thought when i reprogram the bios chip it will gone.
        Real Time Clock Error - Check date and time.
        Fan Error.
        Thermal Sensing Error.
        thing i do:
        - changing 3.3V Battery.
        - i'm sure that the Fan is working fine and spinning very well.
        - changing the CPU.
        - Finally i'm trying to reprogram Bios Chip's.
        can you help please?
        • peste
          • Dec 2016
          • 13924
          • ROMANIA
          try this..
          • fayal
            • Jan 2015
            • 14
            first bin works perfect thanks peste.
            • herifachri
              • Dec 2019
              • indonesia
              • syairien
                • Sep 2018
                • 9
                • indonesia
                is this bios suitable for those using vga gforce?
                • OKRPKCOMP
                  • Dec 2020
                  • 442
                  • PAKISTAN
                  Originally posted by peste
                  try this..
                  WORKING
                  THANKS
                  • Richie_AA
                    • Mar 2023
                    • China
                    Helps me a lot, HUGE THANKS.
                    • Doniciputat
                      • Aug 2022
                      • 111
                      • Indonesia
                      Thanks master
                      • lucaszmn
                        by lucaszmn
                        Problem:
                        Initial Findings:
                        • I concluded that the
                        08-12-2025, 03:01 PM
                      • to5it0
                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                        by to5it0
                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                        I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                        This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                        I have opened the laptop and identified the main BIOS chip...
                        10-24-2025, 01:35 AM
                      • Joluvillas
                        Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                        by Joluvillas
                        Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                        06-18-2024, 10:35 PM
                      • 1g0r
                        Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                        by 1g0r
                        First, the data in brief:
                        Manufacturer: Lenovo
                        Model: ThinkPad L15 G3 21C3-0016GE
                        motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                        IC Bios 1: MX77L25650F
                        IC Bios 2​: MX25L25673G
                        EC Chip: NPCX997KAABX
                        So far I've been a silent reader, but now I need your help
                        I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                        I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                        The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                        01-18-2025, 02:39 AM
                      • akwky
                        by akwky
                        Hi!
                        04-14-2025, 01:56 PM
