hp pavilion x360 bios bin need
    Re: hp pavilion x360 bios bin need
    Originally posted by satriaevo View Post
    Helo masters,
    please, need bios bin HP Pavilion x360
    11-k145tu
    14975-1
    448.04A26.0011
    blackscreen problems
    Here's your new bios file, try it and give me the results.
    all donations are welcome,
      Originally posted by SMDFlea View Post
      https://www.badcaps.net/forum/showpo...40&postcount=2
      1.1.1.6. CH341A
      Read the guide there: https://winraid.level1techs.com/t/gu...rammer/32948/3
      If you have a black PCB, it is very likely that it needs to be modified for 3V operation instead of 5V. Failing to do so could damage the ROM IC.
      Watch the instructions there:
      https://www.youtube.com/watch?v=-ln3VIZKKaE
      https://www.youtube.com/watch?v=HwnzzF645hA
      Some other suggestions.
      Try using a powered USB hub.
      Choose the bios chip manually from the list,don`t use auto-detect.
      If you have a PC install the CH341A on it and use the PC`s rear USB ports.
      Try in USB 3 ports.
      If you have a soldering iron do the 3V mod,and resolder all the pins on the CH341A ,the build quality on some is terrible.
      Buy a better programmer,such as a TL866II
      Is this ok to order? https://www.ebay.com/itm/37377718308...mis&media=COPY
        hp pavilion x360 m1-U001DX convertible pc bios
        SR2KL
        S/N-8CG61927TR
          SR2KL
          S/N-8CG61927TR
          If your CPU is Intel Pentium N3710, I think your file should be that one (081A2) otherwise you have the rest of the files.
          Model Number: HP Pavilion x360 m1-u001dx
            its boot..on the first boot its say "writing block" then after 100% its restart and return at black screen state.
              you wrote twice....post the name and model of the laptop and the original bios..and someone will help you...read this too..
                hello i need a bios for hp pavilion x360 convertible 14-dy0005ni
                bios chip damaged
                  bios chip damaged
                  post the serial number..
                    Old backup send
                      model 11-u103nx
                      motherboard -Nougat-kbl mb 16827-1
                        I need bios bin for my hp pavilion x360 14 - chewbacca 14 whl uma 18702 1 448 0E815 0011. Mine powers, no display switch light blinks continuously fast.
                        Below is my bios bin attachment.
                          Here's your New BIOS, it's a Virgin BIOS from HP with your DMI and Windows Key.
                          Serial Number: 8CG852CSKF.
                            Thanks for the quick response. I tried it but it still behaves the same way. Switch light blinks continuously fast.
                              It's a Virgin BIOS, if the below details is yours, you should have a Hardware Issue.
                              Model Number: HP Pavilion x360 14-cd1511sa.
                              CPU: Intel Core i3-8145U.
                                buyrun. Here You are.
                                  My Mode Number: Hp Pavilion x360 14 cd1511sa
                                  Serial Number 8CG852CSJC
                                    Originally posted by ros View Post
                                    13-s19nr 14265-1 bios bin plz
                                    Hello house, pls I need help with a bio's reprogramming
                                    I'm unable to even read the bios because it's marking is Mxic mx 77L12850F as against the usual Mxic 25******* I've been reprogramming, how do I go about reprogramming please
                                    My Bios programmer: xgecu pro tl866 II plus (along with its accompanying bios programmer software)
                                    Laptop model I'm trying to reprogram: hp pavilion x360 14-dy0025nia
                                      I also realized that when I take out the bios chip from the motherboard and on the switch it doesn't blink. Except when the bios chip is on. What could be the problem.
                                        You could have a Hardware Issue, Post your Problem there:
                                        https://www.badcaps.net/forum/forumdisplay.php?f=23
                                          i need the bios for :
                                          hp x360 310 g2
                                          HEVIN-BSW 6U MB
                                          15200-1
                                          448.04A36.0011
                                          i attach my backup of the original bios .
                                          Thanks in advance
