hp pavilion x360 bios bin need
  • hardware1
    • Sep 2021
    • 2949
    • N/A
    #121
    Re: hp pavilion x360 bios bin need
    Originally posted by satriaevo
    Helo masters,
    please, need bios bin HP Pavilion x360
    11-k145tu
    14975-1
    448.04A26.0011
    blackscreen problems
    Here's your new bios file, try it and give me the results.
    all donations are welcome,
    • Kiekko
      • Aug 2022
      • 31
      • Finland
      #122
      Originally posted by SMDFlea
      https://www.badcaps.net/forum/showpo...40&postcount=2
      1.1.1.6. CH341A
      Read the guide there: https://winraid.level1techs.com/t/gu...rammer/32948/3
      If you have a black PCB, it is very likely that it needs to be modified for 3V operation instead of 5V. Failing to do so could damage the ROM IC.
      Watch the instructions there:
      https://www.youtube.com/watch?v=-ln3VIZKKaE
      https://www.youtube.com/watch?v=HwnzzF645hA
      Some other suggestions.
      Try using a powered USB hub.
      Choose the bios chip manually from the list,don`t use auto-detect.
      If you have a PC install the CH341A on it and use the PC`s rear USB ports.
      Try in USB 3 ports.
      If you have a soldering iron do the 3V mod,and resolder all the pins on the CH341A ,the build quality on some is terrible.
      Buy a better programmer,such as a TL866II
      Is this ok to order? https://www.ebay.com/itm/37377718308...mis&media=COPY
      • Nurshad
        • Oct 2019
        • 75
        • bangladesh
        #123
        hp pavilion x360 m1-U001DX convertible pc bios
        SR2KL
        S/N-8CG61927TR
        • hardware1
          • Sep 2021
          • 2949
          • N/A
          #124
          SR2KL
          S/N-8CG61927TR
          If your CPU is Intel Pentium N3710, I think your file should be that one (081A2) otherwise you have the rest of the files.
          Model Number: HP Pavilion x360 m1-u001dx
          • satriaevo
            • May 2017
            • indonesia
            #125
            its boot..on the first boot its say "writing block" then after 100% its restart and return at black screen state.
            • peste
              • Dec 2016
              • 13691
              • ROMANIA
              #126
              you wrote twice....post the name and model of the laptop and the original bios..and someone will help you...read this too..
              • tauzman
                • Jul 2021
                • 18
                • South Africa
                #127
                hello i need a bios for hp pavilion x360 convertible 14-dy0005ni
                bios chip damaged
                • peste
                  • Dec 2016
                  • 13691
                  • ROMANIA
                  #128
                  bios chip damaged
                  post the serial number..
                  • hashirclt
                    Banned
                    • Nov 2020
                    • india
                    #129
                    Old backup send
                    • Nivosysknr
                      • Jan 2019
                      • 9
                      • India
                      #130
                      model 11-u103nx
                      motherboard -Nougat-kbl mb 16827-1
                      • apostsamking
                        • Dec 2017
                        • 118
                        • Ghana
                        #131
                        I need bios bin for my hp pavilion x360 14 - chewbacca 14 whl uma 18702 1 448 0E815 0011. Mine powers, no display switch light blinks continuously fast.
                        Below is my bios bin attachment.
                        • hardware1
                          • Sep 2021
                          • 2949
                          • N/A
                          #132
                          Here's your New BIOS, it's a Virgin BIOS from HP with your DMI and Windows Key.
                          Serial Number: 8CG852CSKF.
                          • apostsamking
                            • Dec 2017
                            • 118
                            • Ghana
                            #133
                            Thanks for the quick response. I tried it but it still behaves the same way. Switch light blinks continuously fast.
                            • hardware1
                              • Sep 2021
                              • 2949
                              • N/A
                              #134
                              It's a Virgin BIOS, if the below details is yours, you should have a Hardware Issue.
                              Model Number: HP Pavilion x360 14-cd1511sa.
                              CPU: Intel Core i3-8145U.
                              • cihat966
                                • May 2018
                                • turkey
                                #135
                                buyrun. Here You are.
                                • apostsamking
                                  • Dec 2017
                                  • 118
                                  • Ghana
                                  #136
                                  My Mode Number: Hp Pavilion x360 14 cd1511sa
                                  Serial Number 8CG852CSJC
                                  • Joztu
                                    • May 2022
                                    • 46
                                    • Nigeria
                                    #137
                                    Originally posted by ros
                                    13-s19nr 14265-1 bios bin plz
                                    Hello house, pls I need help with a bio's reprogramming
                                    I'm unable to even read the bios because it's marking is Mxic mx 77L12850F as against the usual Mxic 25******* I've been reprogramming, how do I go about reprogramming please
                                    My Bios programmer: xgecu pro tl866 II plus (along with its accompanying bios programmer software)
                                    Laptop model I'm trying to reprogram: hp pavilion x360 14-dy0025nia
                                    • apostsamking
                                      • Dec 2017
                                      • 118
                                      • Ghana
                                      #138
                                      I also realized that when I take out the bios chip from the motherboard and on the switch it doesn't blink. Except when the bios chip is on. What could be the problem.
                                      • hardware1
                                        • Sep 2021
                                        • 2949
                                        • N/A
                                        #139
                                        You could have a Hardware Issue, Post your Problem there:
                                        https://www.badcaps.net/forum/forumdisplay.php?f=23
                                        • tonytou30
                                          • Aug 2017
                                          • 24
                                          • gard
                                          #140
                                          i need the bios for :
                                          hp x360 310 g2
                                          HEVIN-BSW 6U MB
                                          15200-1
                                          448.04A36.0011
                                          i attach my backup of the original bios .
                                          Thanks in advance
