Hp laptop model m6-k025dx bios needed
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need bios for this model board id: VGU00 LA-9315P REV:1.0
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: Hp laptop model m6-k025dx bios needed
    anyone can help on this please i need a working bios and ec for this
      • 21002
      Heres a virgin bios and EC,extracted from hp bios update.
      • String2016
        • Nov 2015
        • 2238
        • philippines
        @SMDFLEA thank you its working, one thing i ask when it turns on it show message manufacturer unlock mode, is it possible to remove this message during bootup?
          • 21002
          MPM mode will lock itself after 10 reboots. You can lock and unlock it manually, see the first attatchment in Ala_Borbe`s post: https://www.badcaps.net/forum/showthread.php?t=69204 "Manufacture Programming Mode in Unlock mode MPM.zip" .Look at the original.jpg image for instructions.
          Use HP BCU utility in the zip or get latest version from HP . https://ftp.hp.com/pub/caps-softpaq/cmit/HP_BCU.html
          • String2016
            • Nov 2015
            • 2238
            • philippines
            @smdflea its working thank you again
            • legendkray
              BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
              by legendkray
              I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
              07-05-2025, 09:25 AM
            • Reda123456
              HP ENVY Laptop 16-h1023dx bios needed
              by Reda123456
              Hello i got this computer, its the HP ENVY Laptop 16-h1023dx the motherboard code is JPR64 LA-M841P Rev 1.0 2022-12-12 and serial number is CND3420BTN so the problem is that this laptop won't boot to a windows or a bootable windows usb installation or anything, ive updated the bios using hp recover bios tool with a usb drice but still same problem, so i am confused, is this a bios problem or what? And if anyone could gimme a working bios bin i'd appreciate it...
              02-16-2025, 03:06 PM
            • cekcons
              Gigabyte G1 Assasain motherboard Bios IC model or Schematic needed !
              by cekcons
              Gigabyte G1 Assasain motherboard Bios IC model needed !
              Bios ic fried and I cant read the model on top.
              Thanks !
              07-16-2025, 01:22 AM
            • plorp2211
              Need BIOS binary for Positivo BGH laptop model e955x.
              by plorp2211
              Motherboard model HannStar J MV-4 94V-0 E89382
              BIOS chip model 25B64BSIG
              I haven't been able to find anything related to this board at all. I'll attach the BIOS dump and a photo of the motherboard for reference.
              Thanks in advance....
              06-23-2025, 07:42 PM
            • kakazu
              HP Laptop Model 15s-DU0077TX for this model I need bios
              by kakazu
              hello guys if you have bios bin for this
              please attached in the comment sections
              06-10-2025, 11:15 PM
