Hp laptop model m6-k025dx bios needed
  • String2016
    • Nov 2015
    • 2242
    • philippines
    I need bios for this model board id: VGU00 LA-9315P REV:1.0
  • String2016
    • Nov 2015
    • 2242
    • philippines
    Re: Hp laptop model m6-k025dx bios needed
    anyone can help on this please i need a working bios and ec for this
      • 22276
      Heres a virgin bios and EC,extracted from hp bios update.
      • String2016
        • Nov 2015
        • 2242
        • philippines
        @SMDFLEA thank you its working, one thing i ask when it turns on it show message manufacturer unlock mode, is it possible to remove this message during bootup?
          • 22276
          MPM mode will lock itself after 10 reboots. You can lock and unlock it manually, see the first attatchment in Ala_Borbe`s post: https://www.badcaps.net/forum/showthread.php?t=69204 "Manufacture Programming Mode in Unlock mode MPM.zip" .Look at the original.jpg image for instructions.
          Use HP BCU utility in the zip or get latest version from HP . https://ftp.hp.com/pub/caps-softpaq/cmit/HP_BCU.html
          • String2016
            • Nov 2015
            • 2242
            • philippines
            @smdflea its working thank you again
            • Loki_Fido
              BIOS for Microsoft Surface Laptop 7 - Model 2036
              by Loki_Fido
              Hi ya folks,
              Attached is the BIOS from a Microsoft Surface Laptop 7 - Model 2036
              As of right now i am unable to confirm whether this BIOS dump works or not.
              But i will update soon. Hopefully in a day or two.
              Given that no one else uploaded any BIOS backup for this laptop, I thought i might as well start a new thread and upload what i have.
              Microsoft Surface Laptop 7th edition
              Model 2036
              SN 0F3CPFB24153HH
              Remember, If you tried to read this chip with CH341A, this device will not identify this chip for you.
              Both ASProgrammer...
              09-11-2025, 04:00 AM
            • userbtcku
              I need a bios file for a Lenovo Thinkpad P1 Gen 3 laptop, model 20TJS2LA1B
              by userbtcku
              I need a bios file for a Lenovo Thinkpad P1 Gen 3 laptop, model 20TJS2LA1B.
              Can anyone help me find the BIOS file for this laptop?
              This laptop is having trouble booting from a flash drive or SSD.
              I've updated the BIOS with a file downloaded from lenovo.com, but it still doesn't work.
              So I'm thinking of flashing it another way.
              11-19-2025, 02:18 AM
            • legendkray
              BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
              by legendkray
              I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
              07-05-2025, 09:25 AM
            • Reda123456
              HP ENVY Laptop 16-h1023dx bios needed
              by Reda123456
              Hello i got this computer, its the HP ENVY Laptop 16-h1023dx the motherboard code is JPR64 LA-M841P Rev 1.0 2022-12-12 and serial number is CND3420BTN so the problem is that this laptop won't boot to a windows or a bootable windows usb installation or anything, ive updated the bios using hp recover bios tool with a usb drice but still same problem, so i am confused, is this a bios problem or what? And if anyone could gimme a working bios bin i'd appreciate it...
              02-16-2025, 03:06 PM
            • cekcons
              Gigabyte G1 Assasain motherboard Bios IC model or Schematic needed !
              by cekcons
              Gigabyte G1 Assasain motherboard Bios IC model needed !
              Bios ic fried and I cant read the model on top.
              Thanks !
              07-16-2025, 01:22 AM
