Asus x450j mobo SV41JN mb 13320-1
  • nurianto
    • Mar 2016
    • 10
    • indonesia
    Need bios for asus x450j
    main bios 8mb & KBC IT8587E
  • alecs
    Banned
    • Apr 2019
    Re: Asus x450j mobo SV41JN mb 13320-1
    try this
    • nurianto
      • Mar 2016
      • 10
      • indonesia
      Originally posted by alecs
      try this
      Thanks, btw my problem solved
      and this my KBC IT8587E bios backup
      • jokophp
        • Dec 2017
        • 39
        • indonesia
        work for me, problem stuck windows logo, solved..
        • jokophp
          • Dec 2017
          • 39
          • indonesia
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
