HP-15b018CA Bios dump include the KBC?
  • brew99
    • Jan 2019
    • 132
    So I've got this HP-15b018CA motherboard that I grabbed a BIOS dump from. While I was troubleshooting the board, the KBC (ENE KB9028G) let the smoke out. I'm able to get another KBC, but I have no programmer for it. Is this one of those KBC that will be programmed from the BIOS chip (I've read that certain KBC will take the programming from the BIOS)? How could I tell from looking through the BIOS bump if that is the case with this chip?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Bios dump include the KBC?
    If you would have posted your dump here,then it could be stated with certainity that your dump has kbc bios in it or not. usually, the main 8mb dump has kbc dump. Your another query-whether it will program automatically or not(as long as new kbc is blank) cannot be confirmed as i never replaced kbc on this board. On some hp it does program automatically but in most of the cases it doesnt program automatically and you need a kbc programmer to do the job. So no concrete answer from me.
    • brew99
      • Jan 2019
      • 132
      OK here is the dump. If you could take a look and see if the KBC is in it that would be great. But for future learning, what is it you are looking for that would indicate that? I'm familiar with using a HEX editor, or is there some other piece of software that works better?
      • khaahk
        • Dec 2013
        • 830
        • Estonia
        EC content begins at 20 0000 in this dump.
        Search for string "ene" or "ite" depending on the ec type.
        As i see you have already changed the win key to xxxx -s, that's a good practice.
        Another way is to unpack official bios update with phoenixtool and look for appropriate size module in the list of modules.
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • haitham sharabati
          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
          by haitham sharabati
          Hello engineers 😀,
          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
          🔧 Device Info:
          - Model: HP 15-da2007ne
          - Product Number: 8XF55EA#ABV
          - Serial Number: CND0338P0D
          - CPU: Intel Celeron N4000
          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
          💀 Problem:😅
          - Device shows “Administrator Password”...
          08-07-2025, 04:54 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
