HP-15b018CA Bios dump include the KBC?
  • brew99
    • Jan 2019
    • 132
    So I've got this HP-15b018CA motherboard that I grabbed a BIOS dump from. While I was troubleshooting the board, the KBC (ENE KB9028G) let the smoke out. I'm able to get another KBC, but I have no programmer for it. Is this one of those KBC that will be programmed from the BIOS chip (I've read that certain KBC will take the programming from the BIOS)? How could I tell from looking through the BIOS bump if that is the case with this chip?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Bios dump include the KBC?
    If you would have posted your dump here,then it could be stated with certainity that your dump has kbc bios in it or not. usually, the main 8mb dump has kbc dump. Your another query-whether it will program automatically or not(as long as new kbc is blank) cannot be confirmed as i never replaced kbc on this board. On some hp it does program automatically but in most of the cases it doesnt program automatically and you need a kbc programmer to do the job. So no concrete answer from me.
    • brew99
      • Jan 2019
      • 132
      OK here is the dump. If you could take a look and see if the KBC is in it that would be great. But for future learning, what is it you are looking for that would indicate that? I'm familiar with using a HEX editor, or is there some other piece of software that works better?
      • khaahk
        • Dec 2013
        • 760
        • Estonia
        EC content begins at 20 0000 in this dump.
        Search for string "ene" or "ite" depending on the ec type.
        As i see you have already changed the win key to xxxx -s, that's a good practice.
        Another way is to unpack official bios update with phoenixtool and look for appropriate size module in the list of modules.
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • DynaxSC
          by DynaxSC
          11-17-2023, 10:56 AM
        • grimacelord
          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
          by grimacelord
          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
          Motherboard model number: DA0PAMB46A1 REV: A
          Secondary motherboard model number: 0PAB
          SKU: 685K4UA
          Serial number is: 5CD3223BJP
          Recently reflashed this laptop with latest BIOS and once...
          05-07-2024, 08:06 AM
        • DynaxSC
          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
          by DynaxSC
          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
          11-06-2022, 05:22 PM
        • TacticalFahrrad
          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
          by TacticalFahrrad
          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
          06-30-2025, 04:09 AM
