Asus f540sa-xx627t bios
  • ibnalhabit
    • Mar 2019
    • 52
    • ALGERIA
    Salut all
    i need a working bios of ASUS F540SA-XX627T
    mobo / X540SA Rev. 2.1
    i have trying with one but no result
  • peste
    • Dec 2016
    • 13430
    • ROMANIA
    Re: Asus f540sa-xx627t bios
    try...
    https://www.badcaps.net/forum/showthread.php?t=63497
    • ardeyalex
      Banned
      • Feb 2014
      • 36
      • Romania
      here
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
