Asus x540UBR rev 2.0 Bios need
  • mhdabboud
    replied
    can you remove password please....
    replied
    Re: Asus x540UBR rev 2.0 Bios need
    Originally posted by ALIBOFROUD
    hello can any one help
    me ineed x540ubr bios
    ram disable
    Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
    Provide a BIOS/EC dump if possible
  • ALIBOFROUD
    replied
    ram disable
  • dieshrink
    replied
    Re: Asus x540UBR Bios need
    Originally posted by cacla
    Here it is
    Thanx , i confirm it work well
  • cellphoneyeta
    replied
    Originally posted by qayyum786
    fixed
    Thanks bro... I will try and post result later...
  • qayyum786
    replied
    Originally posted by cellphoneyeta
    pls clear my bios back up..
    Thanks in advance.
    fixed
  • cellphoneyeta
    replied
    Thanks in advance.
  • peste
    replied
    Originally posted by tute21
    Hello, I want to do a clear cmos on a mother x540ubr and I can't find the jumpers and I've tried everything to get the bios password and nothing works for me. to be able to do anything else .. I need help please I do not want to throw away the motherboard and in Asus they do not give me a solution
    post the original bios of the laptop...
  • tute21
    replied
  • tute21
    replied
    Hola quiero hacerle un clear cmos a una mother x540ubr y no encuentro los puentes e intentado de todo para sacarle la contraseña a la bios y nada me sirve intente con alt+r y tampoco no puedo iniciar windows ya que enciendo la laptop y me pide la contraseña sin poder hacer mas nada .. necesito un ayuda porfavor no quiero tirar a la basura la mother y en asus no me dan solucion
  • abdelilahocs
    replied
    here it is
    thank u
  • dave2779
    replied
    many many thanks sir
  • Feedot
    replied
    The bios at post #2 work, thank you
  • Eranga Lakmal
    replied
    Please bios for Asus X540UBR ver2.0 bin file
  • ajitqtr@gmail.com
    replied
    Re: asus x540ubr rev 2.0 bios needed
    Originally posted by peste
    try..
    thanks its working:
  • michas1975
    replied
    Here it is
    it works... thanks
  • efkarlim
    replied
    Originally posted by satishkumar
    unfortunately, the buddha trigger
  • efkarlim
    replied
    Unfortunately, I wrote in 2 bios, it still does not trigger any trigger, but I could not write ec. It is written in ecite. I think I only have minipro tl-866cs, so I can not try ec.
  • efkarlim
    replied
    try...
    Unfortunately it didn't trigger again.
  • peste
    replied
    Originally posted by efkarlim
    thank you for your feedback, i have attached the relevant files.
    try...
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • grimacelord
    by grimacelord
    07-10-2025, 02:52 PM
  • jbonavita
    by jbonavita
    Some issues
    Things I tried
    04-29-2025, 09:38 PM
  • throwaway327
    by throwaway327
    Model No: RC72LA
    Serial No: SBNVKD001014459
    06-18-2025, 05:52 PM
  • lrouw84
    by lrouw84
    Hi there,
    01-28-2023, 01:31 PM
