need to remove password from this file ....i tried some files from internet but notebook goes very slow
macbook air ufi lock
Re: macbook air ufi lock
hereAttached Filesif you find these attachements useful please consider making a small donation to the site
Im Back... sort of...
try it
do smc/pram reset
if its still slow maybe its a sensor issueAttached Filesif you find these attachements useful please consider making a small donation to the site
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
by MICHAEL_2013Good afternoon. My client brought me a Mac A2251 EMC 3348 that he bought at a sale. The computer is completely iCloud-free, but it came with MDM installed. He has tried contacting the company that provides the MDM in every way possible, but they are unwilling to offer a solution. The device is:
Model A2251 EMC 3348. Serial Number: C02G54CZML85
Apple MacBook Pro Core i7 2.3, 13" 2020, 512 GB SSD, 16 GB RAM.
I've tried changing the serial number of the SoC ROM MX25U3235F, but it hasn't worked:
C02G54CZML84 only works up to Monterey.
C02G54CZML86 doesn't work (I...-
Channel: BIOS Requests ONLY!
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by envymHi everyone!
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM -
by gjlpereiraHi forum.
I'm working on a macbook pro, model a1708, that is running extremely slow.
Everything on it seams to work just fine, it just works extremely slow; painfully slow; especially running macos (windows and linux actually run OKish on it, slow, but usable).
One other symptom of the problem with the machine is that the fan is always running at full speed.
This machine has been worked on by someone else previously; they tried to repair it, but with no success. The motherboard does have sings of being worked on, but it all looks good/OK; like... -
by ritaloHello,
I have a MacBook Air 13 inches 2014.
I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
I know how to remove the password with a usb programmer.
I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
Then I have to find this value in the file : $SVS because it indicate where is the password.
But I can't find the value.
I have attached the file
Thank...-
- Loading...
