Dell Inspiron 11 3179 (P25T003) Bios Dump
  • Abe777
    • Mar 2019
    • 7
    Hi. I gave my Dell Inspiron 11 3179 (P25T003) to my brother a while back. He thought setting a bios password would give him an extra layer of security against prying eyes and thieves. Unfortunately, that extra security turned around on him, he forgot the bios password and now the laptop is unuseable. I have the service tag number so I decided to call Dell customer service for a master unlock code , but to no avail, the code would not work for some reason (and yes, I tried holding control before I pressed enter after entering the master code, didn’t work either) . I saw people having success by reprogramming the bios chip by using a SOP8 bios chip programmer, I bought one and was successful in reading the bios chip. 3 questions:
    1)Is there a way to remove the bios password manually by editing the code using a hex editor? If so, location of line of code to be edited and instructions on what I need to change.
    2) Or would it be easier to obtain a clean bios firmware and just replace the locked bios firmware already on my laptop? If so, can anyone please provide me with a clean working bios dump for this particular laptop?
    3) if it’s even easier, can anyone provide me a master unlock code that actually works if I provide the service tag number (see pic)?
    Thank you in advance to anyone that may be able to assist me!
  • Abe777
    • Mar 2019
    • 7
    Re: Dell Inspiron 11 3179 (P25T003) Bios Dump
    Here is my service tag number!
    • rioreno
      • Feb 2009
      • 540
      • Indonesia
      Originally posted by Abe777
      Hi. I gave my Dell Inspiron 11 3179 (P25T003) to my brother a while back. He thought setting a bios password would give him an extra layer of security against prying eyes and thieves. Unfortunately, that extra security turned around on him, he forgot the bios password and now the laptop is unuseable. I have the service tag number so I decided to call Dell customer service for a master unlock code , but to no avail, the code would not work for some reason (and yes, I tried holding control before I pressed enter after entering the master code, didn't work either) . I saw people having success by reprogramming the bios chip by using a SOP8 bios chip programmer, I bought one and was successful in reading the bios chip. 3 questions:
      3) if it's even easier, can anyone provide me a master unlock code that actually works if I provide the service tag number (see pic)?
      do you have spiprogrammer? read and post that lockbios here... i try to help to clear the password...
      • Abe777
        • Mar 2019
        • 7
        I do have a spiprogrammer. I have read the bios chip and here's the bin file (attachment). Please excuse me if i posted in an incorrect format or not the way you want. If you need me to post it in a different way, just let me know what you need and i will provide it. I am new to the forums world, so please excuse me in advance.
        Thank You for your help!!
        • Abe777
          • Mar 2019
          • 7
          sorry, didn't attach properly the first time.
          • drgn997
            Banned
            • Dec 2011
            • 19
            Could you provide the master password you received from Dell, either in a post or in a private message?
            Sometimes Dell will ask for the incorrect information to generate the master password. Checking the Service Tag at www.dell.com, it shows this as an "Inspiron 11 3185 2-in-1", I just downloaded the bios update and seems like it uses a System Disable 16-hex code, so there's a possibility they have just asked you for the ServiceTag (which some computers use for unlock, but not this one).
            Computer is still under warranty, so if my assumption is right, then you should provide them with the System Disable code, for which Dell in return will provide you with an 8-digit number.
            Some of these models also have an ENE ec/kbc chip, where the password is stored, password is usually NOT in the bios chip... but your mileage may vary.
            • rioreno
              • Feb 2009
              • 540
              • Indonesia
              greeting abe777
              drgn997 right about type, from your bios are : inspiron 11 3185 with AMD processor..
              but i am sure the password store at bios chip not EC, i have some reason for this...
              1. Until now I never found bios password for AMD base system store at EC chip.
              2. And then this link to make sure :
              hxxps://www.ebay.com/itm/BIOS-CHIP-for-Dell-Inspiron-11-3180-Dell-Inspiron-11-3185-No-Password-/132785362743
              3. However you have to try it, so you'll know whether the is store at bios chip or EC chip...
              4. Better try this file, it was extracted from dell web update..
              goodluck and please confirm...
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                I agree with rioreno-never found password in ec in amd system.
                • Abe777
                  • Mar 2019
                  • 7
                  Thank you so much, it seems to have worked in removing the bios lock (You are 100% correct @rireno, not stored on EC). But now its saying the HDD is locked. I removed the HDD and booted, i was able to gain access to the BIOS settings screen and boot options. I think now all i have to do is format the HDD, as there was really nothing of importance on it, and reinstall the OS, correct?
                  P.S. Out of curiosity, is this normal protocol for when a BIOS password is set? Does it automatically lock the HDD as well?
                  and also, could i have just downloaded a fresh bios file from Dell and extracted the.bin and loaded into the chip? would that have worked or would i still had to make changes for it to work with my specific laptop?
                  Thank you
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    If your hdd is locked, formatting wont remove the password as the password is stored in the logic board of hdd.
                    • drgn997
                      Banned
                      • Dec 2011
                      • 19
                      @ Abe777
                      I've sent you a message, check and follow instructions.
                      • Abe777
                        • Mar 2019
                        • 7
                        @drgn997 it gives me the service tag # J1F29L2
                        sorry for the delayed response
                        • SIISerwis
                          • Aug 2023
                          • 22
                          • Polska
                          Hallo.
                          Hello. Could I ask for the BIOS password to be removed? My child locked it, and I can't seem to do it myself. Thank you very much.
                          Service Tag: CN4V9L2
                          • peste
                            • Dec 2016
                            • 12868
                            • ROMANIA
                            Originally posted by SIISerwis
                            Hallo.
                            try..
                            • lapfix
                              • Mar 2020
                              • 2733
                              • my workshop
                              Hallo.
                              What's the suffix showin !
                              • SIISerwis
                                • Aug 2023
                                • 22
                                • Polska
                                It shows something like this
                                • Stefan Steff
                                  • Mar 2024
                                  • 262
                                  • Romania
                                  Hallo.
                                  Your password is: 748311
                                  • SIISerwis
                                    • Aug 2023
                                    • 22
                                    • Polska
                                    Thank you!!!!
                                    "You're the best, everything works. Will you uncover the secret of how you do it?"
                                      DELL Inspiron 3179 Hybrid (2-in-1) 3000 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 3179 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3179 boardview and 3179 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron...
                                      09-06-2024, 06:02 AM
                                    • zlr8r
                                      looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                      by zlr8r
                                      looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                      cheers
                                      Dell Inspiron 17 (7786) Laptop
                                      Service Tag: 5J0NHT2
                                      Bios: 1.9.0
                                      MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                      Attached;
                                      1. My saved bios using a programmer
                                      2. Dells Bios updater .exe (v1.16)
                                      3. Dells Bios recovery file
                                      4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                      5. Image of ME...
                                      12-18-2023, 03:08 PM
                                    • Ahari
                                      by Ahari
                                      I...
                                      Yesterday, 06:12 AM
                                    • mikeybass
                                      by mikeybass
                                      04-23-2025, 04:30 PM
                                    • GadgetsFix
                                      Dell Inspiron 16 5630 BIOS request
                                      by GadgetsFix
                                      I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
                                      • Model: Dell Inspiron 16 5630
                                      • MainBoard Part Number: 4550SC01C004
                                      • Laptop Serial No: GKH3JX3
                                      • DP/N: 0303KM
                                      • QUAKE N RPL UMA CS MB
                                      • 213251-2
                                      • TMN0H$KB
                                      01-17-2025, 07:38 AM
