Reflash Dell 17R 17r 5721
  • tritron
    • Mar 2019
    • 9
    I just bought Dell 17r 5721 with corrupted bios. It beeps constantly. Can someone tell me what name of bios i need I downloaded latest version from dell
    • 22279
    Re: Reflash Dell 17R 17r 5721
    If you want a bios ask in the bios requests sub-forum. Try different memory, and post how many beeps it makes. https://www.dell.com/support/article...ook-pc?lang=en
    • tritron
      • Mar 2019
      • 9
      Well I need file name. When i hold down end key plug in power it powers on power light blinks but it does not seem to have correct bios name I see usb blink once nothing happens.
        • 22279
        Without pressing any keys,apart from the power button ,how many beeps does it make.Have you tried different memory ?
        • tritron
          • Mar 2019
          • 9
          I tried different sticks It is single beep constantly
          • zenius
            by zenius
            12-08-2024, 06:13 AM
          • mikeybass
            by mikeybass
            04-23-2025, 04:30 PM
          • capoplays
            Help with BIOS update on Dell G15 5515 after chip replacement
            by capoplays
            Hey everyone,
            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
            When I check the BIOS using the F12 menu Flash...
            10-24-2025, 06:53 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • Sathsul
            Dell Latitude 5431 issues with dumping bios
            by Sathsul
            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
            10-28-2025, 07:49 AM
