Asus m60j rev2.0
  • mo4nis
    • Dec 2018
    • 55
    • maroc
    Asus m60j rev2.0
    Need bios + ec laptop
    asus m60j rev 2.0
    • 22275
    Re: Asus m60j rev2.0
    Post your bios backup .
    • mahmoodjavan
      Banned
      • Mar 2018
      • 584
      • iran
      asus m60j rev 2.0
      • mo4nis
        • Dec 2018
        • 55
        • maroc
        thank you friend
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • lrouw84
          Asus vivobook s510ua bios changed to x510un
          by lrouw84
          Hi there,
          I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
          I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
          01-28-2023, 01:31 PM
        • ferah831208
          help with bios decompose for Asus s5506ma
          by ferah831208
          I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
          08-24-2025, 05:35 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
