Asus S551LB rev 2.1 Bios dump
  • rager007
    • Feb 2016
    • 106
    • Usa
  • rager007
    • Feb 2016
    • 106
    • Usa
    Re: Asus S551LB rev 2.1 Bios dump
    • Abdulkadertabbakh
      • Feb 2018
      • 10
      • syria
      thanks teşekkürler.
      • Enes4545
        • Sep 2020
        • 4
        • TÜRKİYE
        I have the same model motherboard, it receives power, it does not give an image. I think the problem is bios. When I wrote this bios, the problem continued. Is there any other bios file?
        • mj-Ashraf123
          • Sep 2018
          • 11
          • india
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • ArkzG
            [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
            by ArkzG
            Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
            What I currently have available:
            - Model: FA506NF (2021)
            - BIOS chip: GD25LQ16 (16Mbit/2MB)
            - Tools: CH341A programmer ready to use
            Does anyone have either a clean 2MB .bin dump of this model,...
            09-26-2025, 09:34 PM
