Asus S551LB rev 2.1 Bios dump
  • rager007
    • Feb 2016
    • 106
    • Usa
  • rager007
    • Feb 2016
    • 106
    • Usa
    Re: Asus S551LB rev 2.1 Bios dump
    • Abdulkadertabbakh
      • Feb 2018
      • 10
      • syria
      thanks teşekkürler.
      • Enes4545
        • Sep 2020
        • TÜRKİYE
        I have the same model motherboard, it receives power, it does not give an image. I think the problem is bios. When I wrote this bios, the problem continued. Is there any other bios file?
        • mj-Ashraf123
          • Sep 2018
          • 14
          • india
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • pirati
            by pirati
            10-27-2025, 04:20 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
