Hp elitebook 745 g3 (AMD) bios password
  • syedtahmed86
    • Oct 2020
    • india
    #41
    Re: Hp elitebook 745 g3 (AMD) bios password
    I am using the hp 745 g3 amd laptop but have forgotten the bios master password .what is the solution and what are the steps to be done.kindly help.
    • peste
      • 13451
      • ROMANIA
      #42
      https://www.badcaps.net/forum/showthread.php?t=79956
      • Porkie18
        • Dec 2020
        #43
        Hi, I have the same Laptop (EliteBook 745 G3) and my question is will the UNLOCKED Binary work in my Laptop also without the SERIAL and UUID? If not what do I need to READ the BIOS to obtain a DUMP so i can perform as above with most others here? Please forgive the lack of full understanding but I do not fully know the NEWER BIOS's that are protected by other methods other than a Jumper
        • qayyum786
          • Aug 2018
          • 1959
          • INDIA
          #44
          if you mean you want to remove password from another motherboard dump than yes if the BID of both motherboard is same
          but it will replace your DMI inof also like serial number,CT number etc
          its better to unlock your original dump from ''HPUnlocker'' tool or
          send your locked backup dump here some one will help you to unlock it
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            #45
            On 745 G2, you can just flash a fresh bios file straight from HP. After a couple of boots, it restores DMI but does not restore the password.
            I guess it might be the same with 745 G3. You must read a backup anyway, just to avoid any problems.
            But to do any of that, you need SPI programmer. There are many of those out there.
            • Porkie18
              • Dec 2020
              #46
              Most helpful, thank you both
              • shaddy254
                • Feb 2021
                • 37
                • kenya
                #47
                Hello members, can someone assist me with this main bios file
                HP Elitebook 745 G3 mx25l12805d bios (16mb)
                • shaddy254
                  • Feb 2021
                  • 37
                  • kenya
                  #48
                  winbod doesnt work on this. My bios is MXIC
                  • webdan
                    • Jun 2023
                    • 14
                    #49
                    I have a HP Elitebook 745 G3, and also i have a password on BIOS. I appeal to the good will of someone to remove that password. Below is my locked BIOS. Thanks in advance.
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #50
                      Read the rules before posting!
                      You MUST:
                      Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
                      Become a Badcaps supporter
                      Thanks to all supporters.
                      • webdan
                        • Jun 2023
                        • 14
                        #51
                        You MUST:
                        Thanks for you notice. I have tried all the good BIOS showed there, in this thread, for this laptop. But the problem is some of them writed in my chip working fine until I update the BIOS. This is the reason that I upload my original BIOS. No problem. I solve it somehow.
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #52
                          There's no need to try other dumps, did you even bother to read BIOS guides, methods, resources and tools thread? Section 3 - "Password removal by laptop brand"?
                          • webdan
                            • Jun 2023
                            • 14
                            #53
                            I`m usually in a hurry up. I`ll throw a watch
                            • Expired
                              • Feb 2023
                              • 34
                              Code:
                              After entering BIOS, go to security tab and reset security settings to default!
                              Model: HP EliteBook 745 G3
                              Serial: 5CG6362ZVN
                              Mac:
                              SKU_ W7T99EC
                              Buildid: 15VMLTCW601
                              Board CT PFLCEOOW8540VS
                              Feature byte: 3X47676J6S6b757H7M7Q7W7saaaEapaqawbUbhcAdU.a3
                              COA: GMP3P-H8NP2-89H4P-8DMVH+XH4C
                              ME version: 25525525565535
                              try and reply with results. The tool i used is RCUlocker
                              • webdan
                                • Jun 2023
                                • 14
                                #55
                                Originally posted by Expired
                                Code:
                                Serial: 5CG6362ZVN
                                Mac:
                                SKU_ W7T99EC
                                In the meantime i learned how to use RCUnlocker, and this help me a lot. Anyway, thank you.
                                • mj-Ashraf123
                                  • Sep 2018
                                  • 11
                                  • india
                                  #56
                                  Good work works great
                                  Can u share the EC BIOS
                                  • chbalnuweit
                                    • Dec 2022
                                    • 18
                                    • Deutschland
                                    #57
                                    The 745 G3 has to chips (16MB and 8MB) 16 MB should be the BIOS, but what does the 8 MB chip do? Is it EC firmware?
                                    Whenever I just flash the 16 MB chip, there is a message that BIOS version missmatch and old BIOS is restored from EC. Any idea how I can fix this?
                                    According to my research the Novoton NPCE586HA0MX is not programmable. So does it have an external eeprom?
                                      Vesko356 commented
                                      Editing a comment
                                      You MUST NOT:
                                      • Post a request in multiple threads
                                      • Post a request multiple times
                                      You MUST:
                                      • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                      • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
                                  • dmcia
                                    • Mar 2024
                                    • mexico
                                    #58
                                    nice work, thanks
                                    • Rambo1556
                                      • Feb 2025
                                      • Philippines
                                      #59
                                      I hope someone can help me remove the BIOS password on my laptop. And run me down on everything what i need to do. I have zero clue on what to do.
                                      I have HP EliteBook 745 G3
                                      Product ID: W7T43EC#UUF
                                      Serial No.: 5CG6216M0Q​
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 12280
                                        #60
                                        Where's backup bios file ?
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • baaligoga
                                          Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                                          by baaligoga
                                          Good day, everyone!
                                          I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                                          I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                                          05-20-2023, 09:48 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          >Read BIOS guides, methods, resources and tools
                                          Ack
                                          >Try the method at BIOS guides, methods, resources and tools before requesting help
                                          Ack
                                          >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                          python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                          01-30-2025, 04:26 AM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
