Need bios dump asus A442UR X442UQ REV 2.0
  • cyngo
    • Jun 2015
    • 219
    • Indonesia
    Need bios dump asus A442UR code board X442UQ REV 2.0
    Thanks.
  • narsil
    Enas
    • Dec 2017
    • 89
    • france
    Re: Need bios dump asus A442UR X442UQ REV 2.0
    Thanks.
    try this
    waiting for your reply
    • cyngo
      • Jun 2015
      • 219
      • Indonesia
      i think it's not the same between a442ur & x442ur.
      • on/off
        • Oct 2016
        • 333
        • Indonesia
        Try compare it.
        Mostly asus X4** and A4** has same bios. Official bios always trusted bro.
        Search on address 5B3E40h same or not. Or you can search string asus on your bios till you find code for your model exactly.
        • hezareh2000
          • Jan 2019
          • 32
          • Iran
          hi, request bios asus a550ldv rev 2.0
          thank you
            • 22276
            thank you
            Start your own thread, this thread is about a A442UR X442UQ REV 2.0 bios.
            • cyngo
              • Jun 2015
              • 219
              • Indonesia
              this backup bios file
              • djoofi12
                djoofi12 commented
                Editing a comment
                work but Nvidia Not detected
            • on/off
              • Oct 2016
              • 333
              • Indonesia
              Try this, hope will helps you
              Note: If you have problem when extract it, try use 7zip.
              • cyngo
                • Jun 2015
                • 219
                • Indonesia
                I have tried this but the problem remains the same. maybe the problem is in another part, maybe vga chip or singlechip
                • zurvanielle
                  • Feb 2017
                  • 137
                  • Philippines
                  tested good
                  • zeypibytescss
                    • Apr 2019
                    • philippines
                    this one is work like a charm. thanks to this
                    • rein2017
                      • Jun 2017
                      • 35
                      • Philippines
                      Originally posted by zurvanielle
                      tested good
                      Thanks bro this one works for me
                      • accucomppc99
                        • Jan 2019
                        • 20
                        • philippine
                        Originally posted by narsil
                        try this
                        Not Working
                        • kodox
                          • Jul 2017
                          • 329
                          • Indonesia
                          Asus X442UQ Rev.2.0 Bios
                          Attached dump with win key erased, no VCC_VCORE on mainboard while other power rail is normal
                          • peste
                            • 13924
                            • ROMANIA
                            Re: Asus X442UQ Rev.2.0 Bios
                            try..
                              • 22276
                              Try this bios. @peste ,check your bios,the first offset at 00 ? .
                              Asus A442UR ,bios X442UR
                              D 240000 - 24FFFF
                              • kodox
                                • Jul 2017
                                • 329
                                • Indonesia
                                it still the same, no vcc_vcore generated.
                                i think processor is dead
                                thank's for helping
                                • peste
                                  • 13924
                                  • ROMANIA
                                  Originally posted by peste
                                  try..
                                  sorry..delete post # 2 ... it doesn't help anyone.
                                  • p5k_deluxe
                                    • Jun 2014
                                    • 10
                                    • Philippines
                                    tested good
                                    thanks man
                                    • marc23
                                      • Nov 2020
                                      • philippines
                                      gud am mga sir..working to bin file n to?...pls comfirm
                                      newbi mi sir mam...tnx reply
                                      • mkdj
                                        by mkdj
                                        Dear all,
                                        10-19-2025, 04:41 AM
                                      • razor_amd
                                        by razor_amd
                                        12-15-2020, 07:07 PM
                                      • pirati
                                        by pirati
                                        10-27-2025, 04:20 PM
                                      • DynaxSC
                                        by DynaxSC
                                        06-14-2024, 03:49 PM
                                      • Ahari
                                        by Ahari
                                        I...
                                        08-13-2025, 06:12 AM
