I need Asus X541UV IT8995E kbc bios
  • ay_bulut
    • Feb 2016
    • 115
    • turkey
    I need Asus X541UJ-G0055T IO rom
    mainboard : Asus X541UV Rev2.0
    Thank you
    • 22279
    Re: I need Asus X541UV IT8995E kbc bios
    The EC should program itself at first boot if its a new IO chip.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      yes, it does so on asus
      • ay_bulut
        • Feb 2016
        • 115
        • turkey
        Re: I need Asus X541UV IT8995E IO rom
        Thank you
        Thank you
        • Martinli
          • Nov 2019
          • Austria
          Hi, is it really self programming? Sorry I have to ask, because this thread is the only one who says that it is so. All others mean to flash it with expensive programmers. I need this info, because I have an defective Asus Vivobook S15 where the bios chip IT8995E is defective (short circuts the 3,3V linear voltage supply) and I want to consider if it is worth to buy one.
          Thanks in advance
          Martin
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Thanks in advance
            Martin
            Yes thats true. All asus mb's programme kbc on first boot as long as kbc is blank.
            • kofe
              • Sep 2013
              • 32
              • Estonia
              How To Fix Problem Not power ASUS X541UVK i5 ... - YouTube
              • debi73
                • Aug 2023
                • 3
                • India
                Here is the Asus X541UV EC ROM (IT8995E IO Rom) bin file + Bios Regeion bin file
                • someonenotyou
                  • Feb 2021
                  • 65
                  • LV
                  Sorry from bringing up this old post, but would it even program itself if there is no EC region in the UEFI?
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
                  • grimacelord
                    by grimacelord
                    07-10-2025, 02:52 PM
                  • jbonavita
                    by jbonavita
                    Some issues
                    Things I tried
                    04-29-2025, 09:38 PM
                  • throwaway327
                    by throwaway327
                    Model No: RC72LA
                    Serial No: SBNVKD001014459
                    06-18-2025, 05:52 PM
