ZBook 15 G1 Bios (not commited state)
  • ZBooker
    • Dec 2018
    • 13
    Hey there,
    I've replaced Motherboard and CPU of my HP ZBook 15 G1.
    Board Partnumber is 734304-001, CPU is i7-4710mq, GFX Quadro K1100m. (CPU used to be 4800mq)
    I set Serial, Board-CT and SKU with Nbdmifit and locked bios.
    Now I receive "machine is not in commited state". What's the reason for that message?
    I've tried to unlock MPM using BiosConfigUtility64 but it will not work.
    Any hints how to fix? Do I need SMC.bin?
    Markus
    *Sorry if I chose the wrong Forum.
  • imranromi
    • Jan 2015
    • 1290
    • Pakistan
    Re: ZBook 15 G1 Bios (not commited state)
    Post here bios dump if you have bios programmer..
    • ZBooker
      • Dec 2018
      • 13
      Hey imranromi,
      thank you for your post and excuse my late reply.
      I have a CH341A programmer. I ve tried to read bios using programmer Version 1.18, 1.29 and 1.40 but it wont even recognize the winbond chip (25Q128FVSQ). I have no idea why it does not work. Removed RAM, HDD, DVD, unplugged front LEDs, Card Reader, main battery and cmos battery.
      Any hints?
      Regards
      ZBooker
      • ZBooker
        • Dec 2018
        • 13
        I got this programmer: https://www.amazon.com/ARCELI-EEPROM.../dp/B077ZBBMHN
        I suppose I need 1,8V Adapter? Any recommendations?
        • ZBooker
          • Dec 2018
          • 13
          So finally I managed to get the bios dump of the board. Could someone unlock it please?
          Thank you!
          • shakeel1984
            • Aug 2019
            • Pakistan
            Hello friend
            i have hp zbook 15 g1 it was working fine suddenly keypad stopped working checked with hardware keypad does,nt work even in bios. someone told me i have clean ME REGIOn
            even new keypad does,nt work. can u please give me cleaned bios bin file plz
            CND4419H1K serial of zbook laptop
              • 22275
              Originally posted by shakeel1984
              Hello friend
              The EC is probably at fault. Can you post your bios backup .
              • shakeel1984
                • Aug 2019
                • Pakistan
                can u please tell me how to take backup and share?? i gave this machine to many technician some says gpu problem some says motherboard issue in short no one is able to figure out .
                sorry for late reply i was out of station
                • Murtaza527
                  • May 2018
                  • 262
                  • Malaysia
                  try this
                  • Harvey
                    • Apr 2007
                    • 264
                    This any use? https://dr-bios.com/articles/how-to-...-in-commit/253
                    • shakeel1984
                      • Aug 2019
                      • Pakistan
                      this one is for me? for laptop keypad problem?
                      • shakeel1984
                        • Aug 2019
                        • Pakistan
                        Originally posted by Murtaza527
                        try this
                        for me to try ??
                        • zlr8r
                          Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                          by zlr8r
                          Greetings
                          I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                          Serial Number: 5CG3202C16
                          Product #/SKU: 739P0AV
                          CT Number: PRTUE00WBI30YX
                          Description: HP ZBook Firefly 14 inch G10
                          BuildID: 23WWWGAZ602#SABU#DABU
                          Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                          MAC address not found.
                          • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                          10-28-2025, 01:56 PM
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
                        • cr4zychriss
                          by cr4zychriss
                          • Rebrand: PC Specialist
                          11-14-2025, 04:04 PM
                        • pirati
                          by pirati
                          10-27-2025, 04:20 PM
                          by Vesko356
                          08-11-2023, 03:27 AM
