I am in need of Lenovo K4450 bios, anyone ?
Lenovo K4450 Bios please ?
Tags: None
Re: Lenovo K4450 Bios please ?
Here ...always upload original it's needed .
Techman1025Attached Filesif you find these attachements useful please consider making a small donation to the site
Techman1025
The BIOS chip is MX25L6473E 8MB chip, yours is 4MB file.
Is that correct ?
The MB code is:
12285-1
48.4LD03.011
LK491sLast edited by sparrow2719; 11-29-2018, 12:29 PM.Comment
Hi that is for your model upload yours i will make sure all is good .
Techman1025Comment
Here it is:Attached Filesif you find these attachements useful please consider making a small donation to the site
Here try this one,built from the extracted bios update 1E8 - 4001e7 , merged with your bios backup and cleaned the ME , + 73C000 - 73DFFF .Attached Filesif you find these attachements useful please consider making a small donation to the site
It turns out a dead VGA problem. But I will definitely keep the file for future use.
Thanks all for sharing.Comment
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
History:
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by mkdjDear all,
I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
Here the steps I have taken to fix the laptop:
- downloaded latest BIOS from Lenovo Website... - Loading...
