workin dump
je70-cp mb 09923-1m 48.4hn01.01m
by BigPeteI recently took a dump of the 4GB EMMC dump of a new and working Panasonic main board and now the TV won't turn on.
The dump was successful and the program finished without errors.
I used a XGecu T48 to do the dump.
I actually had a few issues getting it to go and I might write up something as a bit of a guide as I couldn't find much in English to go from.
One thing I did do was connect a 1kohm resistor from the 1.2v line to the RSTN pin as per the instructions, could this have caused issues?
I also shorted out the crystal of the adjoining ECU together and at one... -
by AhariHi all,
I...-
by weisianHi all,
I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...-
by DrSASHello everyone,
I'm trying to recover a ASUS Zenbook Pro 15 Flip OLED (model UP6502ZA, serial R1N0CV06A262028, motherboard 60NB0W20-MB1030) which stopped booting after a Windows 11 update. The laptop powers on but there's no display and no POST.
I have a CH341A v1.612 programmer with a WSON 6x5mm pogo adapter. I managed to get two identical consecutive reads, so I believe my corrupted dump is "reliable".
I've spent the last few days trying to prepare a flashable image from the official ASUS bios file (UP6502ZAAS.312, 19MB) downloaded from their...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
- Loading...
