bios macbook a1278 820-3115-b
  • okbalord
    • Jun 2017
    • 208
    • Algeria
    hi . i need bios dump for macbook 820-3115-b
    thx
    OKBALORD
  • due
    • May 2014
    • 52
    • ps
    Re: bios macbook a1278 820-3115-b
    not tested
    • okbalord
      • Jun 2017
      • 208
      • Algeria
      Thx bro i found the bios and it work fine 100%
      this is it
      OKBALORD
      • kamarulhasan
        • Apr 2013
        • india
        thx
        Hi Share You A1278 820-3115-B Mac Os catalina Supported Firmware
        • lzeta
          • Aug 2020
          • 32
          • Italy
          Hi I have tried all three dumps with a T866A programmer but unfortunately I have not been successful. If I do not uncheck "check id" option the flash does not start and if I uncheck it programming starts but after the first step it stops giving this error:
          Error! Code Address 0x000000 Buf_Val 0xFF IC_Val 0x00
          Can anyone helps me?
          • peste
            • Dec 2016
            • 13924
            • ROMANIA
            check the contract between the chip pins and the programmer ... defective bios chip ..
            • lzeta
              • Aug 2020
              • 32
              • Italy
              Thanks for you answer, the contact are ok. I'm trying to downgrade TL866A firmware, I read about problems with last firmware version. I'll let you know.
              • lzeta
                • Aug 2020
                • 32
                • Italy
                Hi, I've downgraded firmware to 6.70 (I'have not found 6.71) but it have the same error. I'm going to buy new eeprom.
                • lzeta
                  • Aug 2020
                  • 32
                  • Italy
                  Hi, I give you an update. I bought a TL866II Plus and managed to flash the bios. I flashed the last posted, the one ready for catalina, everythings seems to be ok. Now I will try to install catalina.
                  • lzeta
                    • Aug 2020
                    • 32
                    • Italy
                    Hi, everythigs ok. I would like to ask you if is possible to write the original serial number in the posted bin files. I've seen that after flashing the serial number is not the original. Thanks.
                    • lapfix
                      • Mar 2020
                      • 2764
                      • my workshop
                      yes you can , use Hxd , find the SN LINE Than copy/paste
                      • lzeta
                        • Aug 2020
                        • 32
                        • Italy
                        I will try, tnx
                        • p5k_deluxe
                          • Jun 2014
                          • 10
                          • Philippines
                          Thanks man
                          • M4n0l0307
                            • Nov 2020
                            • 172
                            • Republica Checa
                            this is it
                            UMA BIOS! Great, working. Thanks for sharing.
                            • dqtech
                              Badcaps
                              • Jul 2018
                              • 641
                              • N/A
                              thanks
                              • hazem3636
                                • Jun 2022
                                • 35
                                • sa
                                bios help bios 820-3115-B
                                apple A1278 "820-3115-B"
                                hi everyone i received laptop and it has issue with original bios and i don't know if it was the original bin file or not because is was repaired in other place before
                                i'll attached the file which it was in damage BIOS , don't know the status is it the original bin file or not !!!!!!!!!!!!!
                                so please i need good bios bin file
                                A1278 "820-3115-B"
                                EMC :2554
                                SN:C1MPK2YBDV30
                                • hazem3636
                                  • Jun 2022
                                  • 35
                                  • sa
                                  and i have one question please
                                  SN is it include in the Bios Bin file with EMC or not ??????
                                  and also the attached file in my last post need clear my region or not
                                  • hazem3636
                                    • Jun 2022
                                    • 35
                                    • sa
                                    bios clean me region a1278 "820-3115-B"
                                    bump
                                    • peste
                                      • Dec 2016
                                      • 13924
                                      • ROMANIA
                                      Re: bios clean me region a1278 "820-3115-B"
                                      Originally posted by hazem3636
                                      bump
                                      try this
                                      • issam
                                        Banned
                                        • Jan 2019
                                        • 3
                                        • tunisia sousse
                                        hello
                                        please i need bios dump of macbook (A1278)
                                        sn: CPFL1GGQDTY3
                                        issue: no detect internal HDD (the HDD câble has been replaced)
                                        thk you
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
