bios macbook a1278 820-3115-b
  • okbalord
    • Jun 2017
    • 204
    • Algeria
    hi . i need bios dump for macbook 820-3115-b
    thx
    OKBALORD
  • due
    • May 2014
    • 51
    • ps
    Re: bios macbook a1278 820-3115-b
    not tested
    • okbalord
      • Jun 2017
      • 204
      • Algeria
      Thx bro i found the bios and it work fine 100%
      this is it
      OKBALORD
      • kamarulhasan
        • Apr 2013
        • india
        thx
        Hi Share You A1278 820-3115-B Mac Os catalina Supported Firmware
        • lzeta
          • Aug 2020
          • 30
          • Italy
          Hi I have tried all three dumps with a T866A programmer but unfortunately I have not been successful. If I do not uncheck "check id" option the flash does not start and if I uncheck it programming starts but after the first step it stops giving this error:
          Error! Code Address 0x000000 Buf_Val 0xFF IC_Val 0x00
          Can anyone helps me?
          • peste
            • 12806
            • ROMANIA
            check the contract between the chip pins and the programmer ... defective bios chip ..
            • lzeta
              • Aug 2020
              • 30
              • Italy
              Thanks for you answer, the contact are ok. I'm trying to downgrade TL866A firmware, I read about problems with last firmware version. I'll let you know.
              • lzeta
                • Aug 2020
                • 30
                • Italy
                Hi, I've downgraded firmware to 6.70 (I'have not found 6.71) but it have the same error. I'm going to buy new eeprom.
                • lzeta
                  • Aug 2020
                  • 30
                  • Italy
                  Hi, I give you an update. I bought a TL866II Plus and managed to flash the bios. I flashed the last posted, the one ready for catalina, everythings seems to be ok. Now I will try to install catalina.
                  • lzeta
                    • Aug 2020
                    • 30
                    • Italy
                    Hi, everythigs ok. I would like to ask you if is possible to write the original serial number in the posted bin files. I've seen that after flashing the serial number is not the original. Thanks.
                    • lapfix
                      • Mar 2020
                      • 2720
                      • my workshop
                      yes you can , use Hxd , find the SN LINE Than copy/paste
                      • lzeta
                        • Aug 2020
                        • 30
                        • Italy
                        I will try, tnx
                        • p5k_deluxe
                          • Jun 2014
                          • 10
                          • Philippines
                          Thanks man
                          • M4n0l0307
                            • Nov 2020
                            • 165
                            • Colombia
                            this is it
                            UMA BIOS! Great, working. Thanks for sharing.
                            • dqtech
                              Badcaps
                              • Jul 2018
                              • 630
                              • N/A
                              thanks
                              • hazem3636
                                • Jun 2022
                                • 35
                                • sa
                                bios help bios 820-3115-B
                                apple A1278 "820-3115-B"
                                hi everyone i received laptop and it has issue with original bios and i don't know if it was the original bin file or not because is was repaired in other place before
                                i'll attached the file which it was in damage BIOS , don't know the status is it the original bin file or not !!!!!!!!!!!!!
                                so please i need good bios bin file
                                A1278 "820-3115-B"
                                EMC :2554
                                SN:C1MPK2YBDV30
                                • hazem3636
                                  • Jun 2022
                                  • 35
                                  • sa
                                  and i have one question please
                                  SN is it include in the Bios Bin file with EMC or not ??????
                                  and also the attached file in my last post need clear my region or not
                                  • hazem3636
                                    • Jun 2022
                                    • 35
                                    • sa
                                    bios clean me region a1278 "820-3115-B"
                                    bump
                                    • peste
                                      • 12806
                                      • ROMANIA
                                      Re: bios clean me region a1278 "820-3115-B"
                                      Originally posted by hazem3636
                                      bump
                                      try this
                                      • issam
                                        Banned
                                        • Jan 2019
                                        • tunisia sousse
                                        hello
                                        please i need bios dump of macbook (A1278)
                                        sn: CPFL1GGQDTY3
                                        issue: no detect internal HDD (the HDD câble has been replaced)
                                        thk you
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          Yesterday, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
