Problem with CH341A
    Re: Problem with CH341A
    Originally posted by pecrie View Post
    Well I haven't try to flash I2C chips.I only had to reprogram this Winbond bios chip.
    I have the black edition and I downloaded the software from the video link from this guy NSC
    Like I said , it is not working when you use a clip and cable.Better to take the chip off the board.
    I also dld the software update.I have for the SETUP_EXE version 1.5.3.0
    and for the CH341A_EXE version 1.18.0.0
    I had no problems to reprogram the chip - and the software did detect the chip.
    Also R/W was no problem -
    I wrote , i desolder the chip.can you send me the Software do you use ?
      Hi ,
      I believe it is the latest , but I'm not really sure.Anyway it worked for me.
      Also I will attach some pictures - printscreens.
      You can download the software for free.
      Furthermore it doesn't make a great difference if you choose the serial driver setup- you will get the same installation files
      That is as far as I could see.
      When you connect 341 to your pc the power led will lit.It means that it gets the 5 Volts.
      In the lower right corner of the flash program screen you will see : connected
      This does not mean , that it has seen a bios chip.When you put a bios chip , the other led (RUN) will lite up.
      The software has noticed the chip.When you press the "detect" button , the Run led will blink 1 time and continues to lite up.
      If it has detected the right brand and model chip , you should be good to go.
      When reading/writing or erasing , the run led will blink with a certain speed.
      Of course , first you should run the setup_exe to install the usb driver files.
      Then you can run the reprogram software - 341A_exe
      I have Win 7 Ultimate 32 bits
      HTH
        Now i have TL866 II Plus and its very good.But i think i damage the BIOS IC or the Motherboard
          do not use the clip.I also had problems with it.best is desolder and use adapter.
            I wrote , i desolder the chip.I dont use clip
              https://www.badcaps.net/forum/showth...t=67346&page=2
