Lenovo L560 - bios PWD
  • magneh
    • Apr 2014
    • 585
    • Portugal
    Hello!
    I have 3 Lenovos L560 with bios PWD.
    Can anyone help me removing it or explain how to do it?
    Here's the U2 BIOS dump.
    Board specs :
    Bios chip 25q128fvsq
    KBC Nuvoton NPCE388NA1DX
    Board LA-C421P rev 1.0
    Thanks in advance!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo L560 - bios PWD
    Your file password cleared. Enjoy.
    • magneh
      • Apr 2014
      • 585
      • Portugal
      Wow thank you
      Just to be sure, this dump can be used on the other 2 L560 I have here with same BIOS PWD issue?
      Thanks!
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Originally posted by magneh
        Wow thank you
        Thanks!
        Yes you can but you may end up with late display. That might require cleaning the me region.
        • magneh
          • Apr 2014
          • 585
          • Portugal
          Ok cool, thanks for the info
          I will test it and if I end up with late display I will bother you again if you dont mind.
          Cheers!
          • magneh
            • Apr 2014
            • 585
            • Portugal
            @mcplslg123
            Just flashed the bios and laptop does not turn on.
            Bios NOK?
            I will roll back to the original one and check.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              The bios i have uploaded is extracted from lenovo web update merged with your dump. As long as your backup is ok-it should have worked.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                The kbc in use here is npce388 which is programmable. The password may be stored in kbc also. If you have kbc programmer, then try programming kbc
                • Pferd5
                  • Mar 2018
                  • 68
                  can you explain how you do it or have a link which explains it?
                  • magneh
                    • Apr 2014
                    • 585
                    • Portugal
                    Hi there!
                    I will roll back the bios with the original backup and test it tomorrow.
                    I dont have a KBC programmer unfortunately.
                    Could this be an issue to unlock these laptops?
                    I will update the thread tomorrow.
                    Thanks!
                      • 20391
                      The password is stored in the npce388. You will need a KBC programmer as mcplslg123 said .
                      • magneh
                        • Apr 2014
                        • 585
                        • Portugal
                        Hi!
                        Thanks for the info!
                        So no need to do anything with this chip I've been trying to re program?
                        Just reprogram the KBC then?
                        Can you send me a link or recommend a good KBC programmer for this?
                        would this one be a good option?
                        https://www.ebay.com/itm/ITE-ENE-IO-...:pf:0&LH_BIN=1
                        Thank you
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Yes, just program the kbc. Svod is a good choice.
                          • mahmoodjavan
                            Banned
                            • Mar 2018
                            • 584
                            • iran
                            tankyou
                            • magneh
                              • Apr 2014
                              • 585
                              • Portugal
                              Hi there,
                              Yes, SVOD seems to be a nice programmer.
                              As I dont do these jobs too often, do you think the one I referred could also do the job?
                              Or SVOD is a much better investment long therm wise?
                              Thanks,
                              Jose Rei
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                The programmer in your link is probably Vertyanov which is also a good choice. I dont know about the price difference between svod and Vertyanov in your country. You can go for it or if you dont intende to use it frequently -look for pre-programmed kbc for your model.
                                • magneh
                                  • Apr 2014
                                  • 585
                                  • Portugal
                                  Hi there!
                                  Thanks again for your feedback.
                                  When you mean to look for pre-programmed KBC for this model, you mean the programming for the IC right?
                                  Is this coming with the software of the programmer? or should be downloaded?
                                  Sorry for all the questions again.
                                  PS : I think I can get the SVOD V3 for 150€. maybe its a good investment
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Pre-programmed kbc means the kbc is already flashed with dump specific to that mb. So no need to flash kbc on your end assuming the kbc you buy is ok and correct program is flashed. I advised so as you said you dont intend to use it frequently. Else go for svod3. Its a good investment.
                                    • magneh
                                      • Apr 2014
                                      • 585
                                      • Portugal
                                      Do you know where I could by some programmed KBC's for this particular model?
                                      Once again, thanks for your time!
                                      Cheers
                                      • magneh
                                        • Apr 2014
                                        • 585
                                        • Portugal
                                        Oh dear...
                                        Remember I said both laptops I flashed with the clear Bios did not turned on after?
                                        Just rolled back the dump to the original one, and still no power, nothing.
                                        Quick measurements, 20V entering in the DC jack.
                                        Bios chip Ov in all pins... no good...
                                        No knocked components, bios chip well soldered, no shorts.
                                        What could be the cause for this? KBC chip ?
                                        Kinda lost now...
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • grimacelord
                                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                          by grimacelord
                                          Hello there.
                                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                          History:
                                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                          I searched for this error online and discovered...
                                          03-15-2023, 03:29 PM
                                        • jendkkd jeje
                                          Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                                          by jendkkd jeje
                                          So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                                          I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                                          10-11-2024, 03:12 PM
                                        • mximiliandz
                                          help bios lenovo ideapad s145-14iil type 81w6
                                          by mximiliandz
                                          Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                                          06-20-2025, 06:50 AM
                                        • 1g0r
                                          Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                          by 1g0r
                                          First, the data in brief:
                                          Manufacturer: Lenovo
                                          Model: ThinkPad L15 G3 21C3-0016GE
                                          motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                          IC Bios 1: MX77L25650F
                                          IC Bios 2​: MX25L25673G
                                          EC Chip: NPCX997KAABX
                                          So far I've been a silent reader, but now I need your help
                                          I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                          I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                          The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                          01-18-2025, 02:39 AM
