Lenovo L560 - bios PWD
  • magneh
    • Apr 2014
    • 616
    • Portugal
    Hello!
    I have 3 Lenovos L560 with bios PWD.
    Can anyone help me removing it or explain how to do it?
    Here's the U2 BIOS dump.
    Board specs :
    Bios chip 25q128fvsq
    KBC Nuvoton NPCE388NA1DX
    Board LA-C421P rev 1.0
    Thanks in advance!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo L560 - bios PWD
    Your file password cleared. Enjoy.
    • magneh
      • Apr 2014
      • 616
      • Portugal
      Wow thank you
      Just to be sure, this dump can be used on the other 2 L560 I have here with same BIOS PWD issue?
      Thanks!
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Originally posted by magneh
        Wow thank you
        Thanks!
        Yes you can but you may end up with late display. That might require cleaning the me region.
        • magneh
          • Apr 2014
          • 616
          • Portugal
          Ok cool, thanks for the info
          I will test it and if I end up with late display I will bother you again if you dont mind.
          Cheers!
          • magneh
            • Apr 2014
            • 616
            • Portugal
            @mcplslg123
            Just flashed the bios and laptop does not turn on.
            Bios NOK?
            I will roll back to the original one and check.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              The bios i have uploaded is extracted from lenovo web update merged with your dump. As long as your backup is ok-it should have worked.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                The kbc in use here is npce388 which is programmable. The password may be stored in kbc also. If you have kbc programmer, then try programming kbc
                • Pferd5
                  • Mar 2018
                  • 72
                  can you explain how you do it or have a link which explains it?
                  • magneh
                    • Apr 2014
                    • 616
                    • Portugal
                    Hi there!
                    I will roll back the bios with the original backup and test it tomorrow.
                    I dont have a KBC programmer unfortunately.
                    Could this be an issue to unlock these laptops?
                    I will update the thread tomorrow.
                    Thanks!
                      • 21932
                      The password is stored in the npce388. You will need a KBC programmer as mcplslg123 said .
                      • magneh
                        • Apr 2014
                        • 616
                        • Portugal
                        Hi!
                        Thanks for the info!
                        So no need to do anything with this chip I've been trying to re program?
                        Just reprogram the KBC then?
                        Can you send me a link or recommend a good KBC programmer for this?
                        would this one be a good option?
                        https://www.ebay.com/itm/ITE-ENE-IO-...:pf:0&LH_BIN=1
                        Thank you
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Yes, just program the kbc. Svod is a good choice.
                          • mahmoodjavan
                            Banned
                            • Mar 2018
                            • 584
                            • iran
                            tankyou
                            • magneh
                              • Apr 2014
                              • 616
                              • Portugal
                              Hi there,
                              Yes, SVOD seems to be a nice programmer.
                              As I dont do these jobs too often, do you think the one I referred could also do the job?
                              Or SVOD is a much better investment long therm wise?
                              Thanks,
                              Jose Rei
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                The programmer in your link is probably Vertyanov which is also a good choice. I dont know about the price difference between svod and Vertyanov in your country. You can go for it or if you dont intende to use it frequently -look for pre-programmed kbc for your model.
                                • magneh
                                  • Apr 2014
                                  • 616
                                  • Portugal
                                  Hi there!
                                  Thanks again for your feedback.
                                  When you mean to look for pre-programmed KBC for this model, you mean the programming for the IC right?
                                  Is this coming with the software of the programmer? or should be downloaded?
                                  Sorry for all the questions again.
                                  PS : I think I can get the SVOD V3 for 150€. maybe its a good investment
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Pre-programmed kbc means the kbc is already flashed with dump specific to that mb. So no need to flash kbc on your end assuming the kbc you buy is ok and correct program is flashed. I advised so as you said you dont intend to use it frequently. Else go for svod3. Its a good investment.
                                    • magneh
                                      • Apr 2014
                                      • 616
                                      • Portugal
                                      Do you know where I could by some programmed KBC's for this particular model?
                                      Once again, thanks for your time!
                                      Cheers
                                      • magneh
                                        • Apr 2014
                                        • 616
                                        • Portugal
                                        Oh dear...
                                        Remember I said both laptops I flashed with the clear Bios did not turned on after?
                                        Just rolled back the dump to the original one, and still no power, nothing.
                                        Quick measurements, 20V entering in the DC jack.
                                        Bios chip Ov in all pins... no good...
                                        No knocked components, bios chip well soldered, no shorts.
                                        What could be the cause for this? KBC chip ?
                                        Kinda lost now...
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • grimacelord
                                          by grimacelord
                                          Hello there.
                                          History:
                                          03-15-2023, 03:29 PM
                                        • to5it0
                                          by to5it0
                                          10-24-2025, 01:35 AM
                                        • mkdj
                                          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                          by mkdj
                                          Dear all,
                                          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                          Here the steps I have taken to fix the laptop:
                                          - downloaded latest BIOS from Lenovo Website...
                                          10-18-2025, 03:43 AM
