Asus X50SL bios/help needed
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. Today it came to pass that my dad's old faithful Asus X50SL notebook lived its last bit of life and died...or rather it's in a coma The problem is as follows: sometimes it posts, other times it doesn't. It just stays there with a blank screen, grinding the CD drive over and over. You remove all power, it would sometimes get it going and other times it doesn't. You leave it alone overnight, try it again, same story: sometimes it fires up, other times it doesn't. I thing it's a GPU issue (it's an AMD), because I blasted the GPU with some hot air knowing they're prone to failure, it worked a couple of times, but then it went back to only starting occasionally whenever it feels like it, with no discernible pattern.
    The reason I believe it may not be related strictly to the GPU however is because it also loses its BIOS settings when it does decide to come on. You'd save them again, it would remember them for a while, until the next time it fails to start. As long as it posts OK it remembers them - it's only when it fails to post that it restores itself to factory defaults, regardless of whether or not you pull the CMOS battery, which I undoubtedly checked and replaced a couple of times now.
    Just for the heck of it, since there's nothing to lose at this point, I want to try flashing its BIOS. During one of its successful startups, I actually updated it from ASUS via the BIOS itself, but it didn't solve the issue.....still, deep inside I know it's probably a GPU or motherboard issue since the display also goes completely blank sometimes all of a sudden....hard to track down really.....what do you guys think ? Can anyone help ? Cheers and thanks.
    Wattevah...
    • 20673
    Re: Asus X50SL bios/help needed
    Try it with different RAM and without the DVD drive.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      I doubt the DVD drive can cause it to fail to post, but doesn't hurt to try and remove as many things from that board as possible....I reckon both the 1GB RAM sticks are fine. I tested them individually in different slots and the same thing happen....sure, it could very well be that both are bad since I don't recall successfully completing a memtest86 test with them - it would freeze before it would get to complete it, although it wouldn't catch any errors either....
      Wattevah...
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Unfortunately no, even with different RAM and no DVD drive the laptop still blanked out during a memtest...I can't quite correlate the blanking of the screen with the loss of BIOS settings though...
        Wattevah...
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • exerion5000
          Bios Needed For Asus X515EA Pcb X415EA R2.0
          by exerion5000
          Asus X515EA_No Power_GD25B127D@SOIC8.rar
          Hi Everyone! , i need repair the original bios corruptes of this model machine (Bios Needed For Asus X515EA Pcb X415EA R2.0) , the unit no power on , i test several bios for this model with some issues maybe related to especific version (keyboard partially work or no work , SSD no detected ,Etc ) so y let more data below if help , many thanks in advance!...
          02-17-2025, 01:34 PM
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
