Need Dell 5010 Clean ME Bios Dump
  • dimah77
    • Sep 2016
    • 149
    • ALGERIA
    Hi guys,
    After reprogramming bios chip of a Dell N5010 in order to remove passwor, it boot up but shutdown after 25 sec
    Bios file used was readed from another Dell working perfectlu
    So i want try reprogramming with Clean ME REGIOON file please
    • 22293
    Re: Need Dell 5010 Clean ME Bios Dump
    Theres a guide here: https://winraid.level1techs.com/t/gu...lization/31277
    If you can`t do it,post your bios backup .
    • dimah77
      • Sep 2016
      • 149
      • ALGERIA
      Thanx a lot, i follow the tutorial and generating NEW file but still the same result, here is my backup file
        • 22293
        Try this one, and give feedback .
        • dimah77
          • Sep 2016
          • 149
          • ALGERIA
          flashing 2 identical motherboard with same file, and same chip (W2532BV)
          Board 1 : work perfect
          Board 2 : shutdown after 35 Sec ( Fan speed increasing before shutdown )
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Check whether you are getting vcc and gfx core on board2 before it shutsdown. Was it working perfectly before bios flash??
              • 22293
              If you do get vcc and gfx core on board 2 post the original bios if you have it.Board 1 might have a different version EC to board 2 .
              • dimah77
                • Sep 2016
                • 149
                • ALGERIA
                must flash it with same EC file as board 2 ?
                  • 22293
                  Post the original bios backup from the board thats not working .
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mikeybass
                    by mikeybass
                    04-23-2025, 04:30 PM
                  • capoplays
                    Help with BIOS update on Dell G15 5515 after chip replacement
                    by capoplays
                    Hey everyone,
                    I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                    The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                    When I check the BIOS using the F12 menu Flash...
                    10-24-2025, 06:53 AM
                  • Akhlz001
                    by Akhlz001
                    09-20-2025, 07:15 PM
                  • jhanra
                    by jhanra
                    in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                    11-02-2024, 04:19 AM
