Need Dell 5010 Clean ME Bios Dump
  • dimah77
    • Sep 2016
    • 147
    • ALGERIA
    Hi guys,
    After reprogramming bios chip of a Dell N5010 in order to remove passwor, it boot up but shutdown after 25 sec
    Bios file used was readed from another Dell working perfectlu
    So i want try reprogramming with Clean ME REGIOON file please
    • 20581
    Re: Need Dell 5010 Clean ME Bios Dump
    Theres a guide here: https://winraid.level1techs.com/t/gu...lization/31277
    If you can`t do it,post your bios backup .
    • dimah77
      • Sep 2016
      • 147
      • ALGERIA
      Thanx a lot, i follow the tutorial and generating NEW file but still the same result, here is my backup file
        • 20581
        Try this one, and give feedback .
        • dimah77
          • Sep 2016
          • 147
          • ALGERIA
          flashing 2 identical motherboard with same file, and same chip (W2532BV)
          Board 1 : work perfect
          Board 2 : shutdown after 35 Sec ( Fan speed increasing before shutdown )
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Check whether you are getting vcc and gfx core on board2 before it shutsdown. Was it working perfectly before bios flash??
              • 20581
              If you do get vcc and gfx core on board 2 post the original bios if you have it.Board 1 might have a different version EC to board 2 .
              • dimah77
                • Sep 2016
                • 147
                • ALGERIA
                must flash it with same EC file as board 2 ?
                  • 20581
                  Post the original bios backup from the board thats not working .
                  • mikeybass
                    by mikeybass
                    04-23-2025, 04:30 PM
                  • jhanra
                    by jhanra
                    11-02-2024, 04:19 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • gizaha
                    by gizaha
                    02-13-2024, 07:18 AM
                  • mido50
                    Dell Precision T5500 Bios dump
                    by mido50
                    Hi, I need Dell percision T5500 bios dump
                    I tried extracting the ones from dell's website
                    but they are not the same size as the one saved feom the bios chip.
                    or if their is a way to make the one from dell's website work when programed to bios chip.
                    Thank you in advance for your help.
                    05-23-2024, 06:07 AM
