Lenovo G480 bios file repair
  • salawayon
    • Nov 2012
    • 578
    • philippines
    no display problem on this one..
    infos:
    LG4858L UMA MB
    12206-1
    48.4WQ02.011
    I attached my backup....
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo G480 bios file repair
    Dear friend, here is tested ok dump for your motherboard.
    • cihancyber
      • Mar 2017
      • 22
      • tejhi
      thanks
      • gustarom
        • May 2013
        • 44
        • indonesia
        thanks
        • hugitos.9564
          • Oct 2019
          • 4
          • Bolivia
          infos:
          LG4858L UMA MB
          12206-1
          48.4WQ02.011
          bios with password....
          • traka24
            • Jul 2020
            • estados unidos
            ask for password the bios you can pass it. thank you very much
            • saloz
              • Jul 2021
              • mexico
              my friend can you pass the password please?, please, thanks
              • saloz
                • Jul 2021
                • mexico
                infos:
                LG4858L UMA MB
                12206-1
                48.4WQ02.011
                my friend, can you pass the password please?, thanks
                • Selmineos
                  • Aug 2021
                  • Colombia
                  No pass, this file is compress to winrar with new encrypt method, please update winrar or used izarc or your compress manager in last update.
                  • fireworks
                    • May 2021
                    • 4
                    • Philippines
                    Hi why is it the bios file above when extracted the file is in vlc? I need lenovo g480 bios bin please..
                      • 21677
                      The above extracted file is a bin. The problem is VLC sets itself as the default app to open .bin files,you can change that by setting the file extension manually to none or to always open with a different app as default. I have set all bin files to open with HxD hex editor. If you want your programmer to open a bin file as default right click on the bin,then select "open with" then "choose default program" then choose the default app and tick the box "always use the selected program..."
                      Change your windows explorer folder options as well from Hide default file types so that you can see all file extensions
                      • fireworks
                        • May 2021
                        • 4
                        • Philippines
                        OK thank you very much. I'll try it.
                        • hoanglaptop
                          • Dec 2021
                          • viet nam
                          pass?
                          • thedoger82
                            • Jul 2017
                            • 24
                            • colombia
                            Hi there... Thanks for this dump, i think is working, but it is password protected... anyidea where is the password in the bios program so i can delete? Thanks a lot!!!
                            • peste
                              • Dec 2016
                              • 13420
                              • ROMANIA
                              try..
                              • thedoger82
                                • Jul 2017
                                • 24
                                • colombia
                                Originally posted by peste
                                try..
                                Thanks a lot!!! ill try and post results!!!!
                                Edit: It has no password now!!! Thanks thanks!!!
                                try..
                                Do you mind to explain just a little bit, how you found the password, im used to mac, but no PC...
                                Thanks again you just have saved my friend's computer!!!
                                • Forest79
                                  by Forest79
                                  However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                  07-23-2023, 07:39 AM
                                • survivalbloke
                                  Unable to extract bios file from Lenovo bios exectuable
                                  by survivalbloke
                                  I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                                  Code:
                                  "innoextract 7wcn38ww.exe"
                                  it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                                  The trouble I'm having is that I'm not getting the newly...
                                  06-12-2024, 07:55 AM
                                • maanee11
                                  Help to get Lenovo BIOS bin file for Thinkpad T560
                                  by maanee11
                                  Hello Everyone,
                                  I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                  https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                  In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                  05-15-2022, 11:59 AM
                                • survivalbloke
                                  Unable to extract Lenovo BIOS file from installer
                                  by survivalbloke
                                  I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                                  I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                                  How can...
                                  07-16-2025, 03:21 PM
                                • pcwhiz24
                                  Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                  by pcwhiz24
                                  Model: Lenovo IdeaPad 3 14ADA05 81W0
                                  S/N: PF2BZS7D
                                  I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                  I already have a CH341A programmer...
                                  04-07-2025, 07:10 PM
