i have this laptop and the bios chip was faulty and can't read or detect it on my programmer ,so i'm not able to take a bios backup, i have a blank chip same model and size i just need the bios dump for this model .. it is Intel version with intel graphic - laptop model # dv5-1334ca - Part Number:504642-001
hp dv5-1334ca bios dump needed
Re: hp dv5-1334ca bios dump needed
there is two dumps for your model ...try and replyAttached Filesif you find these attachements useful please consider making a small donation to the site
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by cekconsGigabyte G1 Assasain motherboard Bios IC model needed !
Bios ic fried and I cant read the model on top.
Thanks !-
by greeliddHi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...-
by TyMercerApologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
- Loading...
