XS
hp probook 650 g3
HP ProBook 650 G3 Notebook PC (ENERGY STAR)_P83Help needed
i received a laptop HP ProBook 650 G3 Base Model Notebook PC (ENERGY STAR)
Board Code: CLOONEY-6050A2860101-MB-A01
Serial No: 5CG7235R57
Fault: Board on, lights on, after a while fan spins fast and no display
when i remove ram then there is ram beep
Checked hardware, 3+5 vots ram vots, processor volts and assolation is ok
Somebody already changed its bios, i dont know its original backup or not
I need a working clean bios for this model
Backup attachedAttached FilesLeave a comment:
Help needed
Backup attachedLeave a comment:
Thread merged.
You MUST:- Post under a related thread if it exists
Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Please, I need a BIOS file. There is no display
HP ProBook 650 G3 6050a2868801-mb-a01
Re: hp probook 650 g3
Not working. Only caps lock stay light up. With another bios found on this site works but no dmi information. I will post bowf bios, mine (corrupted) and the working but no dmi informationAttached FilesLeave a comment:
try..Attached FilesLeave a comment:
Try and Give Feedback.
New built+ your DMI + you win key + clean MEAttached FilesLeave a comment:
hp probook 650 g3
Can anyone help to fix this dumb? Died during update. I tried bios from site, it worked but no dmi information. Original dumb attached.Thank youAttached FilesLeave a comment:
Can anyone help to fix this dumb, died during update. I tried bios from site, it worked but no dmi information. Original dumb attachedAttached FilesLeave a comment:
Does anyone know how to unlock additional BIOS settings?
i need to change the IRQ on the serial port from 5 to 4 however theres no option to do that in the BIOS.
It seems however that the desktop version of the BIOS does provide that feature.Leave a comment:
hp 650 g3Attached FilesLeave a comment:
HP 650 G3 NOT SHOW graphic IN BIOS HERE IS BIOSAttached FilesLeave a comment:
It’s ok. Thank you brother!! You are the best !Leave a comment:
Try this one.Attached FilesLeave a comment:
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by studdy05Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
Ive got...07-08-2025, 09:24 PM -
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
- Loading...
