Transformer T300L T300LA working bios
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Transformer T300L (T300LA)
    here it is
    i tested it and it works 100%
    Im Back... sort of...
  • flayer23
    • Apr 2012
    • 13
    • france
    Re: Transformer T300L T300LA working bios
    think you for sharing it's difficult to find this dump
    • TECHO TN
      • Jan 2024
      • 66
      • algeria
      here it is
      working 100% you saved me man thank you
      • zPwN!
        ENOVA NE14I310 XU133t rev 1.3 working BIOS
        by zPwN!
        Corrupted BIOS (no WIFI, graphics drivers crashing, USB port reset request failed, etc)
        Working BIOS (taken from 15.0.41.2158_CON_LP_B_PRD_EXTR_AB7F54AC but I fixed some FLEX I/O for sata ssd and GPIO VCCIO config for this model)
        System SKU NE14I310
        BIOS Version APD-BI-14-XU133TR130-TA60F-143-E ?
        Motherboard XU133T rev 1.3
        Serial Number IPNBI3X240SM2A01095
        Processor 11th Gen Intel(R) Core(TM) i3-1115G4 @ 3.00GHz 3.00 GHz
        RAM 8.00 GB
        NOTE: I'm new repairing and not sure if this is everything that needed to be configured, but the BIOS...
        01-03-2025, 01:03 AM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
      • Sparklingx
        CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
        by Sparklingx
        So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
        So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
        now all...
        08-29-2024, 01:53 PM
      • titomno2
        Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
        by titomno2
        Hi guys,
        On motherboard ACER AN515-52 type LAF951P.
        I fixed issue with not starting computer (it was the PQ201 component not working properly).
        But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
        Basically some HDD spin but are not detected by the bios.
        Already tried following:
        checked the 4 data lines
        #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
        #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
        07-28-2024, 08:30 AM
      • Bloodhoundje
        by Bloodhoundje
        03-16-2024, 03:12 PM
