Bios Dump BA41-02206A PIOTEK
  • cellphoneyeta
    ShortedboardGSM
    • Oct 2015
    • 49
    • philippines
    Hi guys anyone has bios dump for Samsung NP300E4E
    board id: BA41-02206A PIOTEK
    Thanks in advance
    • 20889
    Re: Bios Dump BA41-02206A PIOTEK
    Backup your bios, try this one .
    EDIT: this bios is P07RBD
    • cellphoneyeta
      ShortedboardGSM
      • Oct 2015
      • 49
      • philippines
      ok i will try... i will post the result
      • cellphoneyeta
        ShortedboardGSM
        • Oct 2015
        • 49
        • philippines
        no luck sir... still no display
          • 20889
          OK , try this one with cleaned ME ,latest firmware.
          P07RBD
          • cellphoneyeta
            ShortedboardGSM
            • Oct 2015
            • 49
            • philippines
            thanks.. i will try and post the result...
            • sainigolu935
              • Aug 2018
              • india
              thanks sir
              • punkrockpax
                • Feb 2019
                • 23
                • Mexico
                Originally posted by JOSE82
                hola cellphoneyeta
                disculpa...(con qué y cómo programaste me podrías apoyar?
                EZP2013 CH2013B
                You have to desolder the eeprom and put it in the programmer, I suggest you make a backup of your original bios just in case, greetings!
                • quinojuan
                  • May 2019
                  • Argentina
                  Thanks from Argentina.
                  • inter_cyber
                    • May 2014
                    • 8
                    • turkey
                    Thank's from Turkiye
                    • nassimhamdi
                      • Feb 2016
                      • 150
                      • algeria
                      thank you i will try
                      • boskorp
                        • Sep 2019
                        • 8
                        • Bulgaria
                        P07RBD
                        Works fine on Samsung NP300E5V-A01BG same board BA41-02206A
                        Screen back on.
                        • Marcelo De Villa
                          • Mar 2020
                          • Philippines
                          Thank you
                          • essamali
                            • Feb 2012
                            • 9
                            working very well thank you great job
                            • renars777
                              • Apr 2018
                              • Kazakhstan
                              Thank's from Kazakhstan!
                              • rascao
                                • Jul 2020
                                • 51
                                • España
                                thanks the clear ME works really good for the reboot loop on this samsung
                                • M Anis
                                  • Mar 2021
                                  • Indonesia
                                  thank's from Indonesia
                                  • brixlaptoprepair
                                    • Mar 2016
                                    • 15
                                    • canada
                                    thanks its work 100 percent...
                                    • Andyservo
                                      • Jun 2013
                                      • 152
                                      • Indonesia
                                      P07RBD
                                      Thanks @SMDFlea, the Bios is working...
                                      • YMK
                                        • Mar 2020
                                        • 13
                                        • Tajikistan
                                        P07RBD
                                        thanks bro
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          Yesterday, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
