Bios Dump BA41-02206A PIOTEK
  • cellphoneyeta
    ShortedboardGSM
    • Oct 2015
    • 49
    • philippines
    Hi guys anyone has bios dump for Samsung NP300E4E
    board id: BA41-02206A PIOTEK
    Thanks in advance
    • 21932
    Re: Bios Dump BA41-02206A PIOTEK
    Backup your bios, try this one .
    EDIT: this bios is P07RBD
    • cellphoneyeta
      ShortedboardGSM
      • Oct 2015
      • 49
      • philippines
      ok i will try... i will post the result
      • cellphoneyeta
        ShortedboardGSM
        • Oct 2015
        • 49
        • philippines
        no luck sir... still no display
          • 21932
          OK , try this one with cleaned ME ,latest firmware.
          P07RBD
          • cellphoneyeta
            ShortedboardGSM
            • Oct 2015
            • 49
            • philippines
            thanks.. i will try and post the result...
            • sainigolu935
              • Aug 2018
              • india
              thanks sir
              • punkrockpax
                • Feb 2019
                • 32
                • Mexico
                Originally posted by JOSE82
                hola cellphoneyeta
                disculpa...(con qué y cómo programaste me podrías apoyar?
                EZP2013 CH2013B
                You have to desolder the eeprom and put it in the programmer, I suggest you make a backup of your original bios just in case, greetings!
                • quinojuan
                  • May 2019
                  • Argentina
                  Thanks from Argentina.
                  • inter_cyber
                    • May 2014
                    • 8
                    • turkey
                    Thank's from Turkiye
                    • nassimhamdi
                      • Feb 2016
                      • 152
                      • algeria
                      thank you i will try
                      • boskorp
                        • Sep 2019
                        • 8
                        P07RBD
                        Works fine on Samsung NP300E5V-A01BG same board BA41-02206A
                        Screen back on.
                        • Marcelo De Villa
                          • Mar 2020
                          • Philippines
                          Thank you
                          • essamali
                            • Feb 2012
                            • 9
                            working very well thank you great job
                            • renars777
                              • Apr 2018
                              • Kazakhstan
                              Thank's from Kazakhstan!
                              • rascao
                                • Jul 2020
                                • 53
                                • España
                                thanks the clear ME works really good for the reboot loop on this samsung
                                • M Anis
                                  • Mar 2021
                                  • Indonesia
                                  thank's from Indonesia
                                  • brixlaptoprepair
                                    • Mar 2016
                                    • 15
                                    • canada
                                    thanks its work 100 percent...
                                    • Andyservo
                                      • Jun 2013
                                      • 152
                                      • Indonesia
                                      P07RBD
                                      Thanks @SMDFlea, the Bios is working...
                                      • YMK
                                        • Mar 2020
                                        • 15
                                        • Tajikistan
                                        P07RBD
                                        thanks bro
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • mkdj
                                          by mkdj
                                          Dear all,
                                          10-19-2025, 04:41 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          💀 Problem:😅
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
