Dell latitude e5440 bios
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    VAW30 LA-9832P
    Rev 1.0 (A00)
    Doesn't POST, board ir taking 0.2 amps, fan spins and then board shuts off.
    Best Regards,
    Raitis
  • Mr.dialogue
    • Sep 2015
    • 11
    • pakistan
    Re: Need BIOS for Dell E5440
    Originally posted by BremiX
    VAW30 LA-9832P
    Rev 1.0 (A00)
    Best Regards,
    Raitis
    here you go.....ok tested.
    • microchipbtl
      microchipbtl commented
      Editing a comment
      Perfect bin thanks lot
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    Thanks but didn't fix the issue.
    And tip about those two dumps, they are 1kb larger than chip can hold so you need to delete FFs at the end.
    • Fabbrone
      • Jun 2015
      • 158
      • italy
      Hy I am looking for this bios , on board ther is two chip U1 U2 ?
      thanks
      • ridamouh159
        • Nov 2014
        • 365
        • maroc
        Re: Dell latitude e5440 bios
        here is
        with good chance
        • Fabbrone
          • Jun 2015
          • 158
          • italy
          • Fabbrone
            • Jun 2015
            • 158
            • italy
            both sources have a slightly larger (1bit) size from the originals
            • BremiX
              • Oct 2017
              • 64
              • Latvia
              Try these:
              • Fabbrone
                • Jun 2015
                • 158
                • italy
                Perfect now it's working fine Thanks
                • EP3RROR
                  • Jun 2015
                  • 13
                  • Ελλάδα
                  hi, did you find any solution after all? i had the exact same problem. trying flashing both chips but nothing changed.
                  • mahmoodjavan
                    Banned
                    • Mar 2018
                    • 584
                    • iran
                    VAW30 LA-9832P
                    Rev 1.0 (A00)
                    Best Regards,
                    Raitis
                    test plz
                    • inv4der
                      • Mar 2015
                      • 26
                      • Poland
                      I'm looking firmware U38 MEC5057 KBC
                      • Mashra
                        • Feb 2019
                        • Pakistan
                        thank u so much
                        • nabilgo
                          • May 2016
                          • 303
                          • L.A
                          probleme dell e5440
                          this dell take 20 seconde to show up dell logo how i can fix that
                          • Zmyslony
                            • Feb 2019
                            • Polska
                            Re: probleme dell e5440
                            Try to clear Region ME
                            • nabilgo
                              • May 2016
                              • 303
                              • L.A
                              hox i can do it
                                • 20918
                                Originally posted by nabilgo
                                hox i can do it
                                If you`re willing to learn how to do it yourself All info you need is at post #2 https://www.badcaps.net/forum/showth...light=win-raid
                                Use ME Analyzer to check the ME firmware version in your bios dump,then follow the guide at win-raid, or watch youtube videos if you can`t follow the guide.
                                You can also try Intel Easy Clean ME from post #6 https://www.badcaps.net/forum/showth...light=win-raid ,you will still need the correct firmware from win-raid .
                                • nabilgo
                                  • May 2016
                                  • 303
                                  • L.A
                                  Try these:
                                  hey friend your bios work perfect the probleme is the laptop take 45 seconde to show data can u fix it pleas and thx
                                  • imranromi
                                    • Jan 2015
                                    • 1288
                                    • Pakistan
                                    Try this.
                                    • nabilgo
                                      • May 2016
                                      • 303
                                      • L.A
                                      Originally posted by imranromi
                                      Try this.
                                      now it start quick but wifi dosen't work
                                      • gizaha
                                        by gizaha
                                        02-13-2024, 07:18 AM
                                      • jhanra
                                        by jhanra
                                        in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                        11-02-2024, 04:19 AM
                                      • TripTop
                                        Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                        by TripTop
                                        Hi
                                        i have dell latitude E7270 with following symptoms:
                                        - takes long time to restart.
                                        - sometimes powers on and then off
                                        - sometimes while working it just dies,
                                        From googling online bios clean could possible resolve this?
                                        i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                        As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                        I reinstall...
                                        09-09-2024, 02:05 PM
                                      • mikeybass
                                        by mikeybass
                                        04-23-2025, 04:30 PM
                                      • Loli Popu
                                        DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                                        by Loli Popu
                                        Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                                        12-13-2024, 08:29 AM
