Dell latitude e5440 bios
Re: Dell latitude e5440 bios
This is mine, i think it's corrupted because with it the laptop powered on only for 1 sec (the power on LED actually), then off and then nothing.Attached Filesif you find these attachements useful please consider making a small donation to the site
With bios #24 i get "A possible processor failure has occurred." like with another that i tried from the same thread.
I'll check all coils like Spider advised and post results.Comment
Your U1 backup is corrupted,U2 seems ok. When you flashed the bios from post #24 did U1 verify ok ? ,i`d try another bios chip and flash U1 from #24 again
"A possible processor failure has occurred.". Had that on a few dell boards, with the adapter plugged into a cold board if the pch heats up instantly its dead.Comment
Yes it verified correctly but i'll try another U1, i have plenty.
I didn't got the "pch heats up instantly", what do you mean?Comment
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
​https://www.badcaps.net/donateComment
Every donation made will go towards server fees and maintenance costs.Comment
Hi, can you clear ?Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi can somebody help me and fix these bios dump please. The laptop fan spin and stops. Spin and stops repeatedly here are both dumps
by gizahaDell latitude 5580, motherboard cdp 80 la-e151p
Since ssd is replaced and had clean install windows, i've... -
by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
Channel: BIOS Requests ONLY!
by jhanraHi there masters, recently i got a dell 5400 chromebook and wanted to install windows, i searched the internet and i found out other people also wanting a UEFI bios for this model, i searched there is a R/W legacy, but there are bugs like keyboard/trackpad not working, and hard to install.
in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...-
by YOUCEF4787Hello everyone,
I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
Initial Problem:
The laptop was completely dead, no signs of life, no power LED.
Action Taken:
I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
Current Situation & The Main Issue:
The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly.... -
by TripTopHi
i have dell latitude E7270 with following symptoms:
- takes long time to restart.
- sometimes powers on and then off
- sometimes while working it just dies,
From googling online bios clean could possible resolve this?
i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
I reinstall...-
- Loading...
